Old 06-24-2020, 11:51 AM   #1
Astro-Balls
Astro-Balls's Avatar
WTB Power brake conversion
A member here was offering a power brake conversion kit, I can't recall his name..Any Help?
I need a power brake conversion kit for '67 C20 Drum/Drum.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-24-2020, 12:04 PM   #2
Willys_MB
Willys_MB's Avatar
Re: WTB Power brake conversion
Pickmup, Frank! I just did this and I’m so glad I did it
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 06-24-2020, 12:37 PM   #3
Astro-Balls
OK, Thanks, I will look him up..
Old 06-24-2020, 01:13 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Sorry, my systems are for disc brakes only.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 06-24-2020, 01:23 PM   #5
Astro-Balls
OK, Thanks,
I WTB Booster/Master assembly for Drum/Drum. '67 C20.
Old 06-24-2020, 04:54 PM   #6
Willys_MB
Willys_MB's Avatar
I've got a master cylinder I just pulled out of my 68 C2500 that was drum drum. If it's the same as the cylinder used with a booster you can have it for the price of shipping. It'll come with the distribution block and bracket, too. I have no need for it and was contemplating dumping it, but I hate throwing away old parts
Old 06-24-2020, 05:56 PM   #7
First c10
First c10's Avatar
Isn't it just the proportioning valve that would be different?
Booster with Master cylinder doesn't care if its drum/drum, disk/drum or disk/disk but the proportioning valve does. am I missing something?
I know the capacity or volume of the reservoirs makes a difference.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-24-2020, 08:32 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Drum/drum trucks don’t have a proportioning valve.
Just a distribution block.
Keith
Convert to disc brakes.
Old 06-24-2020, 09:42 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I think you could still use his master cylinder and distribution block.... When I put the booster on my White '67 I just unbolted the master from the firewall, pulled it forward and bolted the booster on, then bolted the master up to the booster. I never even unhooked the lines.
LockDoc
Leon
Old 06-24-2020, 09:51 PM   #10
projectking
projectking's Avatar
LockDoc
I’ve done several this way.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 06-24-2020, 09:55 PM   #11
Willys_MB
Willys_MB's Avatar
So it sounds like you can use my free master and block. You’d just need to purchase a booster. I’m not sure if PICKMUP’s booster would work with a drum master
Old 06-24-2020, 10:14 PM   #12
Astro-Balls
I appreciate the offer, Think I will go with the Brothers Master Booster combo..
https://www.brotherstrucks.com/1967-...tinfo/KORN773/
Old 06-25-2020, 08:43 AM   #13
mkmc69
mkmc69's Avatar
The Right Stuff
www.getdiskbrakes.com
mkmc69 is offline   Reply With Quote
Old 07-05-2020, 02:27 PM   #14
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Be careful. That looks like a 9" single diaphragm booster. Not big enough for a truck (heavy). More clearance than a stock unit, but less power. I am considering offering a Drum/Drum system with a "distribution block" that will feature my 9" Dual Diaphragm booster.
Phone: 360-956-7170
Old 07-05-2020, 04:38 PM   #15
Astro-Balls
So would you suggest a 12" Booster? This truck is being fixed up to flip for sale, just want to upgrade the brakes.
This truck has a small block, so clearance isn't an issue.
Let me know when you have yours ready.
Old 07-05-2020, 09:14 PM   #16
randy500
The booster i listed yesterday will bolt up and work fine. Originally the c20 got a dual diaphragm unit but the single i listed will work.
No need to bleed the brakes either, just unbolt the master cylinder from the firewall and stretch the lines forward, sometimes you have to remove the line clamp on the frame.
Remove the pedal pushrod and install the booster.
randy500 is offline   Reply With Quote
Old 07-07-2020, 11:25 PM   #17
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
If you are just "flipping", try a rebuilt booster from local auto parts store. You may still have problems with the old MC or dist block.
I am completing two systems for drum/drum trucks (67-70) and should have pics tomorrow. They may be more than you are looking for, but both are certainly far better than that catalog set you show above..
1. 9" DD booster with correct size MC and new adj dist block. $350 + $75 S/H/I. This is the same size as your original PB sys.
2. 11" DD booster with the same items as #1 above. This is a more powerful system than the original. $375 + $75 S/H/I.
You may need to use two common fittings to attach your lines to the new dist block.
Phone: 360-956-7170
Old 07-08-2020, 09:20 AM   #18
Astro-Balls
Veery interested in your Option #1 above, Let me know when you post pics.
Old 07-08-2020, 12:19 PM   #19
dagnabbitt
dagnabbitt's Avatar
Ebay isn't my first choice to buy from, but I just purchased this one for my 68 drum/drum C20.
I couldn't find a comparable one cheaper anywhere. It arrived yesterday, will install this weekend.
https://www.ebay.com/itm/1967-72-Che...53.m1438.l2649
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 07-08-2020, 04:34 PM   #20
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
That EBAY unit is going the wrong direction. It is much smaller & less powerful than the original. The stock lines to your old dist block may not fit it. Be sure to check your old dist block is not plugged. That small threaded rod to the pedal is not nearly as good as the original.
Here is our new 9" DD drum/drum system. Notice the special lines from the MC to the new dist block and the solid one piece rod to the pedal. Normally the lid & bracket will be silver or zinc gold colored. I do have this one black set from another special order. Take your choice. Any questions---just ask. Thanks, Frank
Phone: 360-956-7170
Old 07-08-2020, 05:42 PM   #21
dagnabbitt
dagnabbitt's Avatar
That certainly looks like a nice beefy set up, wish I had seen it. When I asked about what to do with my truck the forum was strangely silent that day.
http://67-72chevytrucks.com/vboard/s...d.php?t=807542
If I run into any problems with the one I bought I will remember to contact you to see if there is a better option.
Astro-Balls, sorry if I hijacked your thread. BTW I am recovering a dashpad right now using your tutorial.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-08-2020, 09:05 PM   #22
Astro-Balls
I would like that setup with the Zinc, is the booster Zinc also or still black with just the master in Zinc?
Pm me payment info, I would like to order asap.
Old 07-09-2020, 04:05 PM   #23
Astro-Balls
Payment sent, Thanks.
Old 07-21-2020, 08:37 PM   #24
Astro-Balls
Received the Booster/ Master assembly from Frank,
Nicely put together.
A couple items needed to finish the installation,
25" 3/8" Vacuum hose and 5/8" 90 degree 3/8" hose barb.
two brake line adapter fittings,
UPC:
887753627681
7/16-24 in. - 3/8-24 in.
Old 07-22-2020, 09:43 PM   #25
littlehopper
I’d be interested in the master cylinder if still available.
Thank you, Joe
littlehopper is offline   Reply With Quote
