#276 |
![]() Join Date: May 2007
Re: Starting a 52 Chevy 3100 Project.
gorgeous!
#277 |
![]() Join Date: Sep 2017
Looking very nice!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#278 |
![]() Join Date: Apr 2009
I love this build. Your build has saved me a lot of time planning my project , Thank you for such detailed post.
I have been amazed between You , Joedoh , Hussey , Skymags , what you have contributed to this forum.
Desert |
#279 |
What headliner did you go with and how was the install?
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#280 |
looks really good
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#281 | |
Thanks!!!!
Thanks!!!! Quote:
I went with the stock cardboard one. It only took an hour to put it on. I called around to upholstery shops and the cheapest I found was $300 to do a headliner. It was around $65 because I had to buy the center support but if you have that its only $35. You cant beat that. It would not be difficult to glue some upholstery to it as well. I didn't need anything fancy. Thanks!!!!
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 |
#282 |
Sorry, can you guys explain this wiring problem? Which aftermarket fuse boxes come wired backwards?
Desert |
#283 |
The flasher was not working and would just stay on when I used the turn signals. I am using the EZwire wiring harness with the flasher unit that hooks directly to the fuse block. The wires for the flasher must be switched on the fuse block. I don't think this would usually matter but I am running all LED lights. I also have the flasher unit for LED lights.
#284 |
Happy 4th of July!!!!! Thank you to all that have fought for our freedom.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 Last edited by 28TudorAZ; 07-05-2020 at 12:48 AM. |
#285 |
Wired up the stereo and the 6x9 and powered 10" sub woofer. The 6 1/2 speakers in kick panels will hopefully be there this week. Sounds pretty good considering it is missing the 2 front speakers. I guess my next task is the door windows. I am not looking forward to that task.
#286 |
looking good! I bought a set of QM MB Quart speakers that are 1/8th a sphere enclosed I figure I will put in the kicks of a truck some day. I had two sets and like a dummy I sold one set, I dont even remember to who! They only made em for a minute, and you never see them for sale any more.
I bet your truck sounds good, thats a fine looking 4th of july pic too!
#287 | |
![]() Join Date: Sep 2016
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#288 |
I do like your dash. The vents and radio worked great.
#289 | |
I will since its going to my dad but while channel surfing some bumping might have been coming from my garage. ![]() I almost did a newer style double din stereo but glad I did not. I am pretty happy with it. When I put the vents in I tried to mimick the gauge placement. I actually plan to go vintage air so there will be 4 old style matching knobs next to the ignition under the Chevrolet.
#290 |
Hi 28Tudor . . . . 1st off - - - a Very Nice Truck .
Great build from start to Driving ; and for one of the best "Causes"...… your Dad , good on you. Ok . . . this is just info : I have installed all LED lights on my Nova ; installed a 'NAPA flasher # 262 , it made my lights work. But, they would flash 'kinda slow' . . . then, I found this Flasher : ….. AUDEW LED flasher (and its adjustable - rate) https://www.amazon.com/dp/B011BTMDQM...novasitecon-20 (better that adding 'load resistors' , to your lights) . . . and, for my LED's it solved my issue - - - could work for you also, and may be just that simple , as changing your flasher (instead of messing with your wires). Then, it's cheap enough . . . (was # 12.00 , when I bought it). Here's my point - - - works great - - - and, I never adjusted a thing just install . . . like 2 years ago . (I like things that work as advertised) . again , very nice truck & . . . . . MAN, it was HOT in Scottsdale on th' 4th . . . . Have a nice day & stay safe ……………. jim |
#291 | |
On another note I took it to be aligned today. They said it was near perfect and did not need to be aligned and did not charge me. ![]()
#292 |
I created the mounts for the rear bumper. 3 inch square tubing.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 Last edited by 28TudorAZ; 07-27-2020 at 08:52 PM. |
#293 |
Here is the final bumper mounting.
#294 |
I also mounted the A/C controls. I like the way this turned out.
#295 |
great work! i like how the dash came out
#296 |
![]() Join Date: Mar 2011
Both came out great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#297 |
Just love the Patina look of your truck. Can't remember if you said or not but was there any other lettering on the door besides what looks like an eagle?
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 07-28-2020 at 12:49 PM. |
#298 |
wow, both the dash and the rear bumper looks excellent.
I am not sure what to do with a rear bumper on mine, but you have me thinking.... Thanks for the pics, and great looking truck
#299 | |
Thanks. I am pretty happy with it. Definitely worth the extra $50 in knobs. Cant wait to get the actual A/C installed.
Thanks!!!! Quote:
Thanks!!! It says Eagle spirit. I would eventually like to find an artist to paint it the way I really want it. Here is a pic.
#300 |
Took these the other day.
