07-18-2020, 12:34 PM | #1126 | |
Re: A '54 named Busty
Update: after removing the compression coupling I noticed that the bottom shaft was only inserted like 1/4" of an inch instead of like an 1 1/4" glad I took it all apart, by inserting it in fully that lowered the interfering bolt out of the way of the spark plug wire and switching to a shorter bolt fixed the problem. As far as the angle I also noticed that my steering column sags about an inch at the firewall opening, so I must devise a proper lower steering column bracket, looking for ideas/advice? looks like this Ididit beauty is just what the doctor ordered: Last edited by Gregski; 07-18-2020 at 03:32 PM. |
07-18-2020, 07:07 PM | #1127 |
huh I found one of those column clamps in a box of parts I bought and used it on a 41 chevy truck, they are handy! I had no idea where it came from.
you could always just get some bluetooth cordless spark plug wires!
07-18-2020, 08:22 PM | #1128 | |
jk... that was ridiculously clever and funny Last edited by Gregski; 07-18-2020 at 08:27 PM. |
07-18-2020, 08:25 PM | #1129 |
can't wait to install these, and see if she will go into Closed Loop like a good girl
07-18-2020, 11:48 PM | #1130 |
new O2 sensors installed, truck now goes into Closed Loop like it is supposed to, sounds like a Cadillac and a Swiss watch had a baby, lovin' it
07-19-2020, 01:42 AM | #1131 |
Sweet!
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
07-19-2020, 01:11 PM | #1132 |
having fixed our steering column spark plug wire interference problem we moved on to the pesky leaky power steering pump
it appeared the precipitation was limited to only when the vehicle was running, and the steering pump was under pressure further inspection revealed the high pressure hose adapter to the -6 AN fitting as the culprit it appears out of the 47 different adapters we were using the wrong one (imagine that) |
07-19-2020, 01:12 PM | #1133 |
however in an unprecedented happenstance we happened to have the proper one in our drawer of everything you have except what you need
please don't ask me what the different adapter / fittings are called, I reserve the right to Ron Swanson this and I do not wanna know, ha ha |
07-19-2020, 01:14 PM | #1134 |
... literally 5 minutes after we fixed the power steering leak !!!
yup, gosh darn it, the water cooled crank pulley sprung a leak |
07-19-2020, 01:56 PM | #1135 |
The ol' Texas two-step, one step forward, two steps back.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-19-2020, 02:02 PM | #1136 |
ah yup, so off to AutoZone to get a new water pumpulator
07-19-2020, 02:52 PM | #1137 |
ah what the hewk...
yup she runs and drives! |
07-19-2020, 02:54 PM | #1138 |
sorry about the shadows
07-19-2020, 02:56 PM | #1139 |
That is awesome!!
Is that post pumpulator fixin or the heck with it runnin?
07-19-2020, 02:58 PM | #1140 |
Umm, I think you may have sprung a sunshine leak in your bed.
07-19-2020, 03:00 PM | #1141 |
07-19-2020, 03:21 PM | #1142 |
And so they lived happily ever after...
07-19-2020, 03:46 PM | #1143 |
First Test Drive Video post LS Swap
this is nice and gentle since I don't have any conduit on my wiring harness and don't want to risk frying any wires, and you've seen my brakes ha ha or lack there of squeaks and rattles free of charge |
07-19-2020, 04:14 PM | #1144 |
Big day, huge. Congrats.
07-19-2020, 04:48 PM | #1145 |
perfect!
07-19-2020, 06:00 PM | #1146 |
thank you mate, glad I have your attention, got one pesky issue, she rubs in da front passenger side wheel when turning right but not when turning left
I think maybe the previous owner cut the coils to lower her some, not sure, but I expect nothing short of part numbers, bar codes, retailers cats names, and a multitude of suggestions on how to fix it from you, ha ha ready set go... |
07-19-2020, 06:03 PM | #1147 |
Nice job dude!
Remember that all LS swaps demand obligatory burnouts. Right there in the cul de sac will be fine. Don’t be shy.
07-19-2020, 06:07 PM | #1148 |
ha ha, I would but I am already on a first name basis with the HOA since the previous owners cut the tree down in our front yard, replaced bark with white rocks, and painted the side gate the wrong shade of gray without getting their permission before we even moved in, therefor I tread lightly (and keep in mind this is my third truck, so I already laid down some solid one wheel peels in da past, hee hee)
07-19-2020, 10:02 PM | #1149 | |
07-19-2020, 11:24 PM | #1150 |
after a proper power nap it was Game Time
the old pump came off quicker than a prom dress |
