Old 07-19-2020, 09:58 PM   #851
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Didn't get as much done as I quite wanted to. Too hot. Been in the hundreds lately, feels like hundred and ten... Enough wining though.
Inner fenders are primed and undercoated. I also have a sneak peak below. Removed all the hardware from doors, they have been in primer for 6 months or longer and they are ready for 2k and paint now that I have the mirror holes drilled.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-19-2020, 10:44 PM   #852
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
The weather here is funny.
You can be stuck working outside. Sometimes you get a decent breeze but have to put up w/the sun cooking your arse.
Or... You can be in a shop/shelter. You don't have the sun cooking your arse but you'll suffocate from lack of airflow. Pick your poison huh?
We all need a large x larger structure that has roll-up doors @ each end to allow air-flow while keeping the direct sun from cooking us & if that sudden shower pops up we can not panic having to quickly move things under cover.
Then there's the humidity
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-20-2020, 12:22 AM   #853
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: TA_C10: Stage 1
"......Then there's the humidity"
I lived in dallas (garland) area for 10 yrs, after growing up in phx and moving there... my first summer there was the first time I broke a sweat after just going down a flight of stairs! the only thing I miss is the greenery along the freeways.. well and the St. Augustine grass
rodstored-72 is offline   Reply With Quote
Old 07-20-2020, 01:19 AM   #854
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
That's where I am....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2020, 01:25 AM   #855
Scurry67
Re: TA_C10: Stage 1
looking good. what product did you use for the undercoating?
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 07-27-2020, 11:31 PM   #856
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Inner fenders and doors in 2K
I forgot how much work it is to body work and paint. This humidity is unforgiving when it comes to wearing rubber gloves during all those cleanliness phases too. I had sweat just pouring out of the back of my gloves while maneuvering the spray gun it was stupid. I ended up scratching that idea. I'm wearing dry fit everything and I'm still soaked to the bone. I never complain. But dam I won't give up. Even when I start hanging my doors on my rack, and IT COMES LOOSE FROM THE HANGER AND SLAMS ON THE CONCRETE!!! Yep. Came down sideways, all the weight hit on door edge hinge side upper body line. It hit so perfect it shifted the door skin. I was so pissed I think the neighbors will never allow their kids outside again.
After I looked closer, it shifted that outer skin enough that it tore the little ledge for the wing window, I had to weld it back together. I ended up beating the skin back with a sledge and 2-by. Then I hammer and dollied the door edge (impact zone) best I could. It also broke the tack welds holding the outer door skin to the window channel and it not only shifted sideways but out away from window channel. Beat that back in too.
I ended up finishing that up, hung it up again, cleaned it, primed both doors, then put 3 coats of 2k on both doors and both inner fenders. I will have to test for the busted door, pray it isn't too bad and I got it fixed. Will have to grind the window channel and outer skin to re-tack weld but if that's all I will be happy.
All that's left is a tiny bit of sanding and these parts are ready for final paint. Pending the door damage... And don't ask for damage pics, I didn't take any pictures during that savage cursing debacle....
"It's only money".
Old 07-27-2020, 11:38 PM   #857
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
On a good note however, I got siggy mirror parts in mail. I don't have but the one pic but trust me, there are more coming. The parts are almost perfect. I need to smooth sand them down a little and drill a hole on the one blank I got to fully test both pieces. But I already fitted them in the mirror pivot and there are gonna work. These suckers don't look like it but I'm thinking this material will be plenty strong enough.
"It's only money".
Old 07-28-2020, 09:10 AM   #858
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Man what a bummer about the door. I can only imagine the sheer frustration you felt in that moment.
But glad to see you moving forward with body work! It is a ton of work...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 07-28-2020, 09:49 AM   #859
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
I'm sorry to hear about the door. I go postal from time to time when stuff like that happens
Keep sanding you are about there!
Glad to hear the mirror part from siggy is gonna work!! I will get my mirror ordered. Thanks to you both for figuring this one out.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-28-2020, 11:38 AM   #860
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Bummer about the door man. But I'm happy to hear the part is going to work! The collaboration was fun. Happy to help where I can. Let me know if the blank worked better, or the one already with the hole. Or if the hole needs to be moved.
1971Stepside, send me a PM whenever you're ready, I'll get one printed for you.
siggyfreud is offline   Reply With Quote
Old 07-28-2020, 11:40 AM   #861
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah I will have a change or two for you before you send one to 71stepside. Minor. I will be working with it tonight so hopefully I will have all details posted tomorrow morning.
"It's only money".
Old 07-28-2020, 08:39 PM   #862
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Well, it's gonna be a little longer on the mirror fellas. Found a weak point in the new part. It snapped after I got it all together and went to maneuver/pivot the mirror for the first time. I have a message in with siggy with a few changes as well. See what he comes up with.
Round 2
And it was looking so good.....
"It's only money".
Old 07-28-2020, 11:50 PM   #863
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Yep, looks like it broke upon the layer lines. Thats the biggest weakness of 3d printing. The part is as strong as the layer adhesion. That said, I'll print it 90* offset, so the layers run perpendicular to the load direction, and that will more than double the strenght in that area.
Nice thing is once I make the changes the new part will be ready in about an hour! Bad thing is, we haven't yet invented teleportation so you could have it just as quickly . . .
Old 07-29-2020, 09:25 AM   #864
1971Stepside
Almost Satisfied
Re: TA_C10: Stage 1
Keep up the good work gentleman!
Old 08-03-2020, 09:53 PM   #865
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: TA_C10: Stage 1
Keep up the good work. I know it's hard to stay positive sometimes, but you have to keep forging on. I just about had enough with my K10 build when I just found out about the crack in the 4L60E housing. I had no choice but to suck it up and move on. Now my build is complete except for some little things. It feels great! And yours will too. You're doing excellent work.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 08-09-2020, 08:55 PM   #866
T2true
Re: TA_C10: Stage 1
Subscribed...
T2true is offline   Reply With Quote
Old 08-13-2020, 08:18 PM   #867
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks guys. Motivation is still here I promise. However..... Been out of town a couple weekends. And. It's been 100+ degrees in my garage for over a month now. I did not see this coming. And trying to accomplish paint and bodywork in that heat is a NO sir.
This weekend I plan to up early and doing some filler and sanding on body panels. Probably through down sealer on them. But then NEXT weekend I have a 4 day weekend all to myself. So in the next two weeks, updates will be coming.
"It's only money".
Old 08-13-2020, 10:25 PM   #868
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
Yep.... It's hot. Gotta re-work the work schedule. 6-11a & then 7pm -9. Sucks because you have to coordinate making noise or requiring adequate lighting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2020, 04:22 AM   #869
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah definitely up early, break during mid-day. I would pipe in A/C to my garage but wouldn't do any good when you need the door open all the time...
"It's only money".
Old 08-14-2020, 09:42 AM   #870
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
The owner of the complex gave me the option of renting a shop that was fitted w/HVAC. I checked w/the long-time tenant/complex mgr. on what his units electric bill was (because he had the same set-up), & he said it was about $10 a day to keep it @ ~80° but the door had to stay down....
I just couldn't see spending >$300 a month for it. Somedays I wish I would have taken the unit just to have the option.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2020, 02:27 PM   #871
1971Stepside
Almost Satisfied
Re: TA_C10: Stage 1
Any update on the rear view mirror? I'm bored at work, so just checking in
Old 08-18-2020, 02:36 PM   #872
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Woah, crazy timing. New parts just arrived yesterday. I need to smooth them out just a bit and they are ready to test.
"It's only money".
Old 08-19-2020, 12:06 AM   #873
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Fingers crossed. That's about as strong a material as I can print, however there is only so much strength we can built into something that small. PEEK or continuous carbon would likely be stronger, but it takes a special printer for continuous carbon, and something that can get hotter than 300*c for PEEK.
Old 08-19-2020, 09:24 AM   #874
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
PEEK material would most likely work well for this. Tough stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-19-2020, 07:04 PM   #875
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I'm starting to understand why they used metal. So this time it looked like it was going to work. The smaller ball size was the key. So then when I went to attach it to the OE roof arm bracket, it squeezes the stem to create the snug tight fit so mirror stays put.
It crushed under the slightest turn. I went slow on the second part but same result. I put the metal ball back in and it worked perfectly.
Any other thoughts?
"It's only money".
