Old 07-21-2020, 08:57 AM   #1
CarlsLQ9SS
CarlsLQ9SS's Avatar
Restoring my dash pad
I seen a post on here where someone restored their original dash pad. I was wondering what would be the best material to recover one with as i dont want to put a repop on my truck. Thanks in advance, Carl
CarlsLQ9SS is offline   Reply With Quote
Old 07-21-2020, 09:12 AM   #2
Davidf
Re: Restoring my dash pad
No idea how to answer your question. But, if it were me, I would probably call "Just Dashes" (there is another company as well) and ask if they would tackle the job. Fortunately, my dash pad was not original, so it was an easy solution to get another repop which I think is fine.
Davidf is offline   Reply With Quote
Old 07-21-2020, 09:18 AM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
I have been searching the forum and have seen some bad reviews on various manufacturers of them, which pad did you go with for your truck?
Old 07-21-2020, 09:31 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I used one of these in both of my 72's and am very satisfied with them. The key to a good fit is slotting the center holes in the dash a bit (if necessary) and not over tightening the nuts! The Pad will distort if you over tighten the nuts or force a stud through a hole. https://www.classicparts.com/Dash-Pa...oducts/268/3/0
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-21-2020, 09:37 AM   #5
CarlsLQ9SS
CarlsLQ9SS's Avatar
Thank you, I have ordered from them and i am happy with the small parts i got, mainly small interior pieces. I may just get one from them.
Old 07-21-2020, 11:34 AM   #6
A1971Blazer
A1971Blazer's Avatar
Check with member GrumpyOldMan
He was offering a custom dash pad cover for the original dash pad
I bought a repro from SoKy Classics made by DashesDirect...in USA
It fit very well and looks nice
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-21-2020, 12:45 PM   #7
Boog
laying low
Boog's Avatar
There is also a member (an upholsterer) selling dash recovering kits down in the classifieds.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-21-2020, 02:32 PM   #8
Grumpy old man
Grumpy old man's Avatar
1) If your dash is crack free and good all around shape you can recolor it using Sem adhesion promoter and Sem dye , The trick using sem products is to use very LIGHT coats or you'll end up with a glossy look . cost $
2) If your dash is cracked just check with your local upholstery shop to see if they will recover for you . The problem with recovering with vinyl material is very few materials have a bi axial stretch to stretch around the corners without wrinkles, None of which are factory colors/ grain so it has to be seamed and you really need to use good upholstery grade glue or the heat will just let the material release and you'll have a mess, Another problem with wrapping is the material will not go into the lower dash mounting screw holes ,So when you go to install them they will either just pull thru the material leaving a hole or leave a "pulled look" around each hole . cost $$$
3) Just buy a new replacement dash pad ,The trick for installing dash pads is to not over tighten the top mounting nuts ,Too tight and any of them will look wavy . The Truck and car shop has them for $55.00 + cost $$ page 36 of the catalog
http://www.truckandcarshop.com/6072.html
Old 07-21-2020, 02:45 PM   #9
Grumpy old man
Truck and car shop.
Old 07-21-2020, 04:25 PM   #10
54blackhornet
54blackhornet's Avatar
I believe you will be quiet impressed with the pad Southern Kentucky offers. It’s a dashes direct product made in the US.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-21-2020, 06:34 PM   #11
72c20customcamper
72c20customcamper's Avatar
Originally Posted by Grumpy old man View Post
Truck and car shop.
I used this one on my 72 worked out well
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-21-2020, 07:04 PM   #12
bry593
Yes, Southern KY does a good job of weeding out the bad aftermarket parts. They also have as fair a price as you can get for the quality.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 07-21-2020, 09:02 PM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
I got a replacement dash pad about 15 years ago from Dashes Direct and it held up well over the years. I traded it for a blue OEM pad a few years ago.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-21-2020, 09:11 PM   #14
Factory Guy
Factory Guy's Avatar
Before I would buy anything. I think I would try refinishing it as shown in these you tube video's:
This first one is a true craftsman (I love his speaker grill inserts-AWESOME idea).
https://youtu.be/05XrGq734u0
https://youtu.be/m3wCdLJAPgE
https://youtu.be/1klhN8ovMfs
https://youtu.be/cJtRCOWebRc
All 3 doing it a different way but all look much better than what they had!
Pretty amazing results by all of them.
Factory Guy is offline   Reply With Quote
Old 07-21-2020, 09:45 PM   #15
Astro-Balls
Astro-Balls's Avatar
Carl, I can get the vinyl dash cover you want to restore your dash.
Let me know if you want it with a saddle stitch seam or plain.
What color?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-22-2020, 02:04 AM   #16
CarlsLQ9SS
CarlsLQ9SS's Avatar
I need a black one, the one in my truck is cracked but not terrible. I like the stitch seam but what would be the price on each one?
Old 07-22-2020, 09:04 AM   #17
CarlsLQ9SS
CarlsLQ9SS's Avatar
Truck and car shop.
Thank you for all the info and i will probably use the spray for my 72 plastic door panels. The dash pad looks like pretty good quality so i will check into that one as well. I also ordered a catalog from them because it looks like they have some pretty good prices.
Old 07-22-2020, 09:39 AM   #18
70cst
70cst's Avatar
Great info folks...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-22-2020, 09:48 AM   #19
Grumpy old man
They have 2 locations one in CA and the other in NC ordering from the NC store should save you some shipping costs .
Old 07-22-2020, 11:15 AM   #20
Davidf
Brothers.
Old 07-22-2020, 07:48 PM   #21
Grumpy old man
Brothers.
Yeah well ... Any time I go to some specialty shops web site and they have a huge fancy store with tons of "automobilia" hanging on the walls and videos on you tube that aren't always spot on all that screams to me personally is $$$$$$$$$$ this is gonna hurt . Just my Grumpy opinion buy from who ever makes you happy .
Old 07-26-2020, 08:16 PM   #22
CarlsLQ9SS
CarlsLQ9SS's Avatar
Here is what I'm working with, I bought a kit from Astroballs (Mitch). Wondering if I need to take all the old vinyl off of the pad?
Old 07-27-2020, 09:21 AM   #23
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I believe you should ask Astroballs. He made it and knows what he made the pattern to fit. Send him a PM and ask.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-27-2020, 09:41 AM   #24
Boog
laying low
Boog's Avatar
I haven't done one but I would think the result would be better without that hard cracked cover under the new one. In fact somewhere here there is a thread showing the removal of the old cover and someone using something like spray foam or something to fill in and level the foam for a better finish.
Boog
primer is finer
Old 07-27-2020, 11:37 AM   #25
KevinK7
KevinK7's Avatar
Carl,
I just went through this myself (first time, so you could do it) Here's a write-up I did as well. BTW, I got the material from Mitch (Astro-Balls), great guy and the material was super easy to work with. Very happy with the outcome
http://67-72chevytrucks.com/vboard/s...ht=dashpad+diy
Kevin
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
