08-07-2020, 10:10 AM | #1 |
Moderator
Vortec Coolant Bypass
I'm using the following heater valve on my two hoses that run from and to the heater/engine - https://www.oldairproducts.com/produ...ve-kit-50-1555
Say's "Special design diverts coolant directly to the engine, away from heater core, when in the off position to reduce excess heat inside the vehicle" In my minds eye that would mean I shouldn't need a bypass hose on my Vortec head style engine? What do you think?
08-07-2020, 10:45 AM | #2 |
Re: Vortec Coolant Bypass
Not sure on the bypass, I don't run one. Over 60,000 miles with out an issue.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-07-2020, 11:00 AM | #3 | |
Moderator
Ya, I'll probably be okay.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-07-2020 at 11:12 AM. |
08-07-2020, 01:18 PM | #4 |
Not sure on the vortec but I'm using one on my LS....which I've been told needs the bypass
08-07-2020, 03:49 PM | #5 |
my new gm L31 i installed was burping and girggling until i did the little bypass hose from the water pump to intake like a BBC engine has from the factory .
i read a lot and asked a lot on this and it seems 50/50 mix of problems or no problems so try it and you will know . mine would pass gas in to the overflow bottle and then when the blower fan was on you would smell coolant like a bad heater core leaking . also if the vehicle is quiet i was hearing the rad cap letting it past .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-08-2020, 01:34 AM | #6 |
Vortec block or no? I am told the some of the blocks have the bypass in them, in turn which does not require the bypass from back of intake manifold.
This is a roller motor no doubt. Here is a pic |
08-08-2020, 01:37 AM | #7 |
I do like what your thinking. Making it comfortable in the Summer. I know that stupid little heater core will take 10-15 degrees off the engine in summer.
08-08-2020, 10:32 AM | #8 |
not the back of the intake . its the front of the intake . the back pass side was just the heater core feed in later years to simplify stuff.
08-08-2020, 11:12 AM | #9 |
I believe it's the vortec heads that don't have the bypass not the block. Could be wrong.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-09-2020, 10:24 PM | #10 |
60-66 Nut
That is correct. Every '95-'02 block I have had, still has the bypass passage as in the pic in toolboxchev's post. It is the Vortec heads that do not have the matching hole drilled in the deck surface. This can be easily drilled when building an engine.
08-09-2020, 11:18 PM | #11 |
I will have to look and drill my two sets of vortec heads if they dont have this hole
In the slow process of pulling one now with my broken leg takes me longer to do these days |
08-10-2020, 09:53 PM | #12 |
60-66 Nut
None of the Vortec heads have that hole drilled in them. That is why the L30 and L31 use an external bypass.
08-11-2020, 03:10 AM | #13 |
The one thing i should ask do you need to drill out front and back of both heads ?
08-11-2020, 03:15 PM | #14 |
It's a lot easier to add a bypass than it is to drill heads.
08-11-2020, 06:41 PM | #15 |
x2
08-11-2020, 09:45 PM | #16 |
60-66 Nut
The bypass is only on the passenger side at the front. If your engine is already together, no need to pull the head. Just plumb in an external bypass as sweeetK30 did.
08-11-2020, 10:06 PM | #17 |
Here's mine. The hose is Gates #12044, cut to fit.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-04-2020, 12:14 AM | #18 |
I see what you mean easier to do the bypass then drill the heads
I did not realize you had to drill the passages in the heads at an angle |
