08-03-2020, 07:33 PM | #26 |
Re: Triumphant Return
08-03-2020, 09:33 PM | #27 |
Took it across the scales today. Just a bit heavier than I figured. This is with me in it, 3/4 tank, and all the tools one would keep in a truck.
08-05-2020, 02:25 PM | #28 |
What heads do you have? 317?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-05-2020, 07:59 PM | #29 |
Yep. Although I have a set of 862s that I’m slowly porting as I get the time.
08-09-2020, 12:12 AM | #30 |
Finally got around to installing the stainless brake hoses in the front end, and let me just say NEVER AGAIN. What a pain! They obviously hadn’t been off EVER and the PO was real lax about letting things leak and accumulate grunge.
I’ve never encountered front hoses that were such a hassle, but the task is done and the brakes are much tighter. The lines also didn’t have a 90 degree bend coming off the caliper. Made for a funky fit, but the manufacturer says these are correct and they do function well. |
08-09-2020, 07:17 AM | #31 |
Nice truck! Looks like a work horse.
08-09-2020, 08:14 AM | #32 | |
08-09-2020, 12:29 PM | #33 | |
My 07 GMC rcsb weighed 4900 with a full tank if gas, and me. |
08-09-2020, 04:36 PM | #34 |
08-09-2020, 04:39 PM | #35 | |
I'll lend you some moral support from afar when you do yours. |
08-09-2020, 04:44 PM | #36 | |
No FF rear here though. This sucker has a 14 SF (weak sauce) and there's no toolbox on it. Just some things under and behind the seat. You're dead on with the bed though. Right around 1,000 lbs. She's just an ol' flat girl. Edit: Nevermind. It is a FF rear end. I don’t know what I was thinking. Last edited by RotaryRocketeer; 08-10-2020 at 03:27 PM. |
08-14-2020, 02:55 PM | #37 |
Driver’s side rear hub bearing started clicking pretty hard a couple days ago. It would seem that the truck’s new heart is a bit too strong for its worn out old ankles.
I’m gonna order parts and do both sides in the same sitting. Y’all got any advice or tips and tricks to help it go smoothly? I’ve never done anything to a 14 bolt FF, so any advice is appreciated. |
08-15-2020, 10:03 AM | #38 |
It was not your engine that damaged your 14 bolt. They are pretty indestructible. Most likely it was just age or a bad seal. They are very forgiving if you make sure you replace the bad parts with good name brand stuff.
