Old 08-08-2020, 04:57 PM   #226
SIXTY9
Re: '72 Cheyenne K10
Looking good.
SIXTY9 is offline   Reply With Quote
Old 08-08-2020, 07:57 PM   #227
jimbosprint
jimbosprint's Avatar
The ducts are in the dash like spaghetti.
jimbosprint is offline   Reply With Quote
Old 08-09-2020, 06:16 AM   #228
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by jimbosprint View Post
Harmonic balancer bolt was just missing. I got a new bolt at the parts store and installed the new pulley without any issues.
Attachment 2039087
Attachment 2039088
Attachment 2039089
Awesome,......
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-09-2020, 04:43 PM   #229
jimbosprint
FedEx said my compressor and controls were delivering yesterday but they didn't show. So today I played with wiring for the new gauges. Temp and volt gauges will be custom fit into the cluster, and the tachometer will hose clamp onto the steering column.
Old 08-09-2020, 07:32 PM   #230
NorCalC20LWB
Jimbo, you will love your VA unit. Had mine charged Friday and took it out today to the Placerville wine country, high 90's to 100 and blew ice cold. Took no time at all to start blowing cold after starting up in a hot cab. The original AC in my truck never worked, so I can't compare to stock, but I really don't think it would be better than this.
NorCalC20LWB is offline   Reply With Quote
Old 08-09-2020, 07:35 PM   #231
jimbosprint
Did you put a fan in front of the condenser, or just the regular Vintage Air setup?
Question - does it use a regular factory AC belt?
Old 08-09-2020, 08:00 PM   #232
NorCalC20LWB
Here's the belt I used, Gates, pretty sure 58" I think which is what VA recommended, stock pulleys. Not sure what you mean about fans, I have a stock setup.
Old 08-10-2020, 01:38 PM   #233
jimbosprint
Custom voltmeter and temperature gauges are in the instrument cluster. They look good in the daytime, but I wonder how they will look at night with the lights on.
Old 08-10-2020, 01:49 PM   #234
Ol Blue K20
They look good. Don't forget to take a night pic for us.
Dale
Old 08-11-2020, 04:41 PM   #235
jimbosprint
Today's progress (so far):
  • The dash is all back together and the tachometer is installed
  • The Vintage Air controls are installed
  • Compressor brackets sandblasted and painted
  • Inner fender reinstalled
  • Alternator belt reinstalled
Old 08-11-2020, 10:58 PM   #236
jimbosprint
How does an old work truck not have any tie-down anchors? I fixed that.
Old 08-12-2020, 12:49 AM   #237
jimbosprint
Here's that night dash photo. The tach ground is not hooked up yet, and I have to figure out why a few of the LED bulbs aren't working.
Old 08-12-2020, 10:41 AM   #238
SRU1436
Attachment 2040041
I’ve only briefly messed with my dash lights, most work but not all. From my research it maybe the circuit board that is causing some of the lights to not work. Some of my sockets work and some don’t even after changing the bulbs, knowing the bulbs worked in a different socket. I’m probably gonna order a new circuit board and see if that is the issue.
SRU1436 is offline   Reply With Quote
Old 08-12-2020, 11:00 AM   #239
SRU1436
It’s all looking good, great job.
Old 08-12-2020, 12:02 PM   #240
jimbosprint
Compressor install was easy. I really appreciate the previous owner using anti-seize on the exhaust bolts. Now I am on the hunt for a shop with the crimping tools to make the AC hoses.
Can anyone tell me if the main power for the Vintage Air is safe to hook up to the battery side of the American Autowire Megafuse?
Old 08-12-2020, 01:15 PM   #241
NorCalC20LWB
[QUOTE=jimbosprint;8790806]Compressor install was easy. I really appreciate the previous owner using anti-seize on the exhaust bolts. Now I am on the hunt for a shop with the crimping tools to make the AC hoses.
Looks really good Jimbo, you are flying along compared to how long it took me. And, yes, you can wire directly into the megafuse terminal coming from the starter. I called AAW about exactly the same thing. They also said most people doing the VA install wire the negative lead to where the negative battery cable attaches to your engine. That's what I did too, looks cleaner.
Old 08-12-2020, 06:56 PM   #242
jimbosprint
I got the AC hoses made and installed. I need a heater hose fitting for the top of the water pump and the heater hoses will be done.
As I suspected, there was no working thermostat. The spring was broken and it was stuck open. I replaced it with a new 180° thermostat.
Old 08-12-2020, 06:58 PM   #243
jimbosprint
Perfect, thank you!
Old 08-13-2020, 12:01 PM   #244
jimbosprint
A trip to the hardware store solved my heater hose plumbing. There was silicone RTV on the plug in the intake, so I put some on the new hose fitting too.
Old 08-13-2020, 08:31 PM   #245
jimbosprint
I finished up the last details for the Vintage Air install today. Wiring is finished, controls are programmed, fans and vents all work properly, and the compressor belt is on. Duralast part 17580 works well for the belt. (I tried parts 15580, 15585, 15570, 17570, and 17590 which all do not fit). I believe it is finally ready for the refrigerant to be charged!
Old 08-13-2020, 11:57 PM   #246
jimbosprint
Vintage Air install is complete! System is charged and everything works! Hot heater, cold AC, and a fan that will blow your hat off.
Old 08-14-2020, 07:48 AM   #247
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Awesome. Can I have your old AC parts?
Old 08-14-2020, 09:20 AM   #248
Ol Blue K20
Attachment 2040534
Great and it looks nice too.
Dale
Old 08-14-2020, 11:04 AM   #249
NorCalC20LWB
Nice timing Jimbo, now you can sit in your truck this week nice and cool when it's 108 out!
Old 08-14-2020, 02:36 PM   #250
cj847
cj847's Avatar
Jimbo,
I am installing a vintage air right now as well. Which hose is supposed to be vertical (ie the dent shape in the cove box)? Is it the passenger defrost or passenger side vent?
cj847 is offline   Reply With Quote
ochre
