Old 08-01-2020, 02:19 PM   #426
Johns 66
Johns 66's Avatar
Re: 1965 LWB Stepside Build
You gonna be riding real soon my friend.
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 08-02-2020, 08:16 PM   #427
roll_the_dice
roll_the_dice's Avatar
Today was a good day! I got my "new" 64 GMC 1 ton delivered and my black walnut wood was delivered. My buddy John (Johns 66) milled and cut the wood for me and Steve (GMCNUT) delivered it along with the truck! It is weird seeing 2 60's trucks sitting in the driveway...Can't start working on this one until I finish the 65...
Can't wait to start finishing the wood. It's going to look killer!
roll_the_dice is offline   Reply With Quote
Old 08-03-2020, 12:07 AM   #428
J Williams
J Williams's Avatar
[QUOTE=roll_the_dice;8786097]Today was a good day! I got my "new" 64 GMC 1 ton delivered and my black walnut wood was delivered.
Trucks look great! But dang you are crazy! I don’t have enough time to work on 1 truck!
Both projects look fun though. Keep it up!
J Williams is offline   Reply With Quote
Old 08-03-2020, 11:37 AM   #429
roll_the_dice
Thanks...I don't have time to work on more than 1 either, but I am so close to finishing my 65, I can wait to work on the 64 until I finish the 65. I hope to get the 65 to the exhaust shop at the end of the week.
All I need to do to get the 64 driving is change out the gas tank (which I have) and put a new master cylinder/bleed the brakes.
Old 08-03-2020, 03:49 PM   #430
Johns 66
Johns 66's Avatar
Yepper...cant wait to see the bed all buttoned up!!!
2019 GMC AT4
Old 08-11-2020, 12:47 PM   #431
roll_the_dice
Put my "new" radiator support on today that I got from John. Thanks John! My old one had some waviness in it (last picture) and had more rust holes than I liked. This one is so much better! I also drilled a 1/4" hole in for drainage in the area that usually rusts out on these. Hope it helps.
Going this afternoon to talk to a shop about exhaust and charging up the A/C. Hope to have the rest of the front end on this weekend.
Old 08-11-2020, 01:42 PM   #432
cwcarpenter98
cwcarpenter98's Avatar
The "new" support looks so much better! Keep up the good work!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-11-2020, 04:17 PM   #433
roll_the_dice
Thanks Christian...I appreciate it.
I stopped at O'reilly's today for a lower radiator hose. They let me go in the back and look at all the ones they had. I found one that I thought would work based on water pump location ...so I took a chance and bought it and came home and it fit perfectly without cutting to size at all! I am stoked about that! Now I just need to find my hose clamps.
Old 08-11-2020, 08:27 PM   #434
Johns 66
Johns 66's Avatar
Definitely looks better......Im glad I could help.
2019 GMC AT4
Old 08-12-2020, 02:55 PM   #435
straight6chevyguy
straight6chevyguy's Avatar
Looking good!
And I like the new truck too!
It would be hard for me to keep my attention on just the one truck lol.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 08-12-2020, 03:09 PM   #436
roll_the_dice
Originally Posted by straight6chevyguy View Post
Looking good!
Thanks, I appreciate it. I had someone interested in buying the orange truck yesterday...enough $ and I can part with it. LOL
I can see the finish line on the white truck...that is my only focus right now.
Edit: I forgot to say..when I do the orange truck, I want a flat bed and rails like yours!
Old 08-12-2020, 03:10 PM   #437
roll_the_dice
Got the drivers inner fender on today and mounted everything tight. So weird seeing it go back together...it's been so long I forgot what it looked like!
Old 08-12-2020, 03:47 PM   #438
J Williams
J Williams's Avatar
Hey! Slow down, you’re making me look bad!! Haha, I was the same way when I put the front end on. You forget how sexy these old trucks look!
63 C10
Old 08-12-2020, 04:18 PM   #439
Johns 66
Johns 66's Avatar
Looking great Andy...you will be rolling in no time at all!!!
2019 GMC AT4
Old 08-12-2020, 04:55 PM   #440
roll_the_dice
Thanks J & John! I couldn't help but put on the front passenger fender while I was looking at it. Need to do a little adjusting, but no point in doing that until I get the grill support installed....but it is starting to look like a truck.
I need to clean up the grille support and clear coat it...maybe get it on this weekend or get the work done this weekend.
Anyone know what size bolt is in the bottom of the fender well where it attaches to the cab?
Old 08-12-2020, 05:05 PM   #441
cwcarpenter98
That lower rad hose is nice! Do you still have the part numbers for both upper and lower hoses? I want to get rid of the crappy looking flexible hoses that I have
Christian Carpenter
Old 08-12-2020, 05:17 PM   #442
roll_the_dice
The lower hose is Gates 20475. 1 3/4" ID. The only difference is I moved my engine forward 2", so this one might not fit yours because of length from water pump to radiator.
The top hose is the one that was on my truck when I bought it. I haven't replaced it yet, but it seems to be in good condition. I cut about 2" off on the engine side from original. I think it is a standard 1 1/2" C10 hose and cut to length. At least the shape looks that way to me.
Old 08-12-2020, 06:33 PM   #443
cwcarpenter98
Oh yeah, I forgot you had moved yours forward. That hose will probably be too short for mine. Time to do some searching lol
With the fender on, it's starting to look like a truck again!!
Christian Carpenter
Old 08-12-2020, 09:21 PM   #444
Johns 66
Johns 66's Avatar
Truck Yeah!!!!
2019 GMC AT4
Old 08-15-2020, 02:51 PM   #445
roll_the_dice
Got the drivers fender on before the afternoon rain... after lunch/rain break, I am going to start cleaning the back of my grille support get it ready for POR 15...
Old 08-15-2020, 04:20 PM   #446
J Williams
J Williams's Avatar
Progress is looking good!
63 C10
Old 08-15-2020, 06:38 PM   #447
cwcarpenter98
Take it for a spin like that
Christian Carpenter
Old 08-15-2020, 08:06 PM   #448
roll_the_dice
Thanks...It is coming along now! I see the light at the end of the tunnel.
Funn you say that...I said to my wife...want to go for a ride in the truck?! If it had exhaust I would!
I got the back of grille support cleaned up with a wire wheel...going to put some por 15 on it Monday. Then I will clear coat the front of the support and paint the part behind the grille black like original. I hope to get that grille on at some point this week...then the hood!
Old 08-15-2020, 08:07 PM   #449
roll_the_dice
Glad I had this emblem to remind me what truck I had. It has been so long I almost forgot!
Old 08-16-2020, 05:54 PM   #450
roll_the_dice
Trying to keep from buying "new parts"...I am doing some cleaning up on the grille/grille support...decided to see if I could clean my headlight bezels...blasted them, then sanded with 220 and 320 grit paper...night and day difference. Going to clear coat them this week so they don't rust again...
One bezel done, one to go!
