Old 08-23-2020, 10:53 PM   #51
focusedontheprize
focusedontheprize's Avatar
Re: 1990 V2500 Suburban Build Thread
It looks incredible!
focusedontheprize is offline   Reply With Quote
Old 08-24-2020, 12:26 AM   #52
kwmech
How many sq ft of the rattle trap did you go through to do the top and bottom?
Old 08-24-2020, 11:51 AM   #53
Ryan Hubbard
I believe I used three rolls
Ryan Hubbard is offline   Reply With Quote
Old 08-29-2020, 11:13 PM   #54
Ryan Hubbard
Today I started the engine swap on my suburban
First Pic is "PREOP" before it went into the shop.
Second pic is of all the parts delivered to the shop.
Old 08-29-2020, 11:15 PM   #55
Ryan Hubbard
Here is the after the first day of work
Old 08-29-2020, 11:16 PM   #56
Ryan Hubbard
Prepping the LS3
Old 08-30-2020, 06:03 PM   #57
kwmech
I see rolls in 25, 50, and 100' lengths
pretty sure 3- 25s will not do it considering the amount of sq footage in this things
Old 08-30-2020, 07:35 PM   #58
Ryan Hubbard
Day number two,
Got the engine and gas tank out. Changed the fuel pump and fuel sender.
Also made a bracket for the Gas pedal to bolt in. I also removed all the TBI wiring.
I removed the oem cross piece and put in a ORD unit and realized the ORD unit would not work with the oil pan I have but the oem one will. So I will stick with the oem one.
Old 08-30-2020, 07:36 PM   #59
Ryan Hubbard
Then I used 2 50 ft rolls.
Old 08-30-2020, 07:38 PM   #60
Ryan Hubbard
I have decided to not put the LS3 in and instead install this engine. Of course I need to come up with another $60K for this engine.
Old 08-30-2020, 07:41 PM   #61
Ryan Hubbard
Here is a picture of the complete car, This car is for sale, just $700,000.00 ( Car sold and was shipped to new owner while I was there)
It has a Shelby Serial number.
Old 08-31-2020, 10:26 PM   #62
rodstored-72
chevy truck fan
rodstored-72's Avatar
uuhmmm you realize that is a ford motor! that would for sure be a swap!! that is a really nice car though....
rodstored-72 is offline   Reply With Quote
Old 08-31-2020, 11:38 PM   #63
Ryan Hubbard
LS3 Installed
Old 09-02-2020, 03:24 PM   #64
rodstored-72
chevy truck fan
ryan,
that looks alot ..... more better! now what are you going to do for wiring?
Old 09-02-2020, 08:54 PM   #65
Greenlee
Greenlee's Avatar
Nice looking burb!
Greenlee is offline   Reply With Quote
Old 09-10-2020, 03:21 PM   #66
ShortHaul
ShortHaul's Avatar
Wow. This is amazing. You tear down, bodywork, paint, reassemble and LS swap your burb in the time it takes me to find a set of rear view mirrors looks incredible! Can't wait to see the finished product.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 09-13-2020, 04:11 PM   #67
Corts60
Just here to tinker
Corts60's Avatar
Great work and beautiful burb!
Old 09-13-2020, 08:18 PM   #68
Ryan Hubbard
Engine is finished and last Thursday I drove the Suburban from Provo, UT to So Cal to do the "break-in" of 640 miles. I am really happy with the set up. I have been tuning the transmission and have it almost done to my liking.
Old 09-14-2020, 12:26 PM   #69
rodstored-72
chevy truck fan
ryan,
looks very good & that is a heck of a break in drive!! nice job!! would you be willing to share what you did for wiring... aftermarket or ??? again nice job!!
Old 09-14-2020, 11:00 PM   #70
Ryan Hubbard
Originally Posted by rodstored-72 View Post
ryan,
The LS3 E-Rod comes with everything, the wiring harness, the computer and the power center. It was real easy to install the wiring. The computer and the "power center" were a little tricky to find where to mount under the hood.
Old 09-15-2020, 07:12 PM   #71
rodstored-72
chevy truck fan
I guess the components are GM factory stuff? specifically the harness and power center?
.. I ask because I am doing a LS swap in my '86 and I am trying to use the factory underhood fuse box & harness from the donor truck. I was not able to get the whole vehicle
would you be willing to post pic(s) of the harness and power center by chance?
Old 09-16-2020, 03:42 PM   #72
Low Elco
Great work on this gorgeous truck! Where did you get the intake tube?
Low Elco is offline   Reply With Quote
Old 09-26-2020, 10:40 PM   #73
Ryan Hubbard
Here is the following list of parts I used for this LS Swap with:
NAL-19370414 Chevrolet Performance LS3 E-Rod Crate Engine
CMB-03-0263 LS Fuel Filter Kit Black
DAK-CRC-200-3 Dakota Digital Cruise Control Kit
HLY-20-143 Holley Accessory Drive Component Mount w/Alternator and PS Pump
HLY-20-133 Holley A/C Bracket
HLY-21-1 Holley LS Engine Accessory Drive Kit
ICB-551600 Oil Cooler Adapter
SPE-900235 Spectre Air Intake Kit
Dirty Dingo 73-87 4WD Chevy LS Engine Mounts
Dirty Dingo E38 Gen IV PCM Billet Mounting Plate
Spintech 8000 Truck RV Muffler
AP Exhaust X6008 Mandrel Bent 3" tail pipe
Earl Fitting 961956ERL Power Steering Fitting
Earl Fitting 961961ERL Power Steering Pump Fitting
Old 09-26-2020, 10:44 PM   #74
Ryan Hubbard
Here is a picture of the power center and ecu mounted
Old 12-07-2021, 11:49 PM   #75
Ryan Hubbard
Well since the last post I have driven the Suburban 30,000 miles and I can say the thing works great. I moved from So Cal to Utah and towed my enclosed car trailer behind the suburban every round trip.
I did lose overdrive with my 4L80E but I had one day left on the warranty for my transmission so it was rebuilt under warranty.
I have really dialed in the transmission and added the Dakota Digital cruise control and it made the long trips really nice to drive.
