09-11-2020, 08:54 AM | #1 |
WTB 292 Air Cleaner Housing
Looking to buy an air filter housing for a 292. I really just need the lower part that the filter sits in. Must be for a 292 as the 250's are shorter. Thanks!
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
09-12-2020, 12:01 AM | #2 |
Always on the hunt...
Re: WTB 292 Air Cleaner Housing
If you are unsuccessful in locating the lower filter housing by itself, we have this complete 292 air cleaner setup available. This setup was removed from a 72 Chevy C/30 with 292 I-6, only offering complete as pictured with upper offset lid, lower filter housing, carb to lid spacer/riser, lower block to housing support rod bracket and carb to upper lid stud. If interested, funds can be sent via paypal, check or money order, if using paypal option add 3%. Thanks, Mel
. ***After letting the offer ride out for a few days over the weekend, we have listed/offered this 292 air cleaner setup in a parts board F/S thread, if you change your mind feel free to post interest in the below linked thread.*** http://67-72chevytrucks.com/vboard/s...d.php?t=811934 . Last edited by Classic Bowties; 09-14-2020 at 03:53 PM. |
09-12-2020, 07:38 AM | #3 |
Thanks, If I can't find just the part I need, I'll get in touch with you.
09-12-2020, 09:13 AM | #4 |
I have just changed my truck from a 250 to a 292, I have a few of these air cleaners and I believe they may be the same. The block on the 292 is taller, but the heads are both the same and the manifolds bolt to the head. I may be wrong on this and if I am someone will probably say so. If I'm right it will make your hunt a lot easier.
09-12-2020, 09:46 AM | #5 |
The air filter housing is a couple of inches taller as the filter itself is taller by 2.40 inches. In a Fram filter, the 250 takes a CA189 and the 292 takes a CA192.
If you have a lower housing for a 292, I'm interested!
09-13-2020, 09:26 AM | #6 |
Interesting, were never to old to learn something new. Anything I have would be complete also.
09-14-2020, 06:49 AM | #7 |
What would you want for a complete set up?
09-15-2020, 09:05 AM | #8 |
09-15-2020, 10:13 AM | #9 |
OK Thanks!
