08-31-2020, 08:54 PM | #26 |
Re: K1416 Suburban part-out- Rolling Chassis
09-02-2020, 06:23 PM | #27 |
Sorry for the delay.
Yes that is it. How much? It should fit in a flat rate box.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ My GMC Photos Last edited by wcstory; 09-02-2020 at 06:30 PM. |
09-03-2020, 08:58 AM | #28 |
I really don't know how to price this other than I know how much time I have in it. How does $25 sound? It does fit in a USPS Large Flat Rate box, so total would be 25+21.10+PP fees. PM sent for payment info should you want it.
SOLD Last edited by VictoriaHardware; 09-08-2020 at 04:30 PM. |
09-04-2020, 08:12 AM | #29 |
i`m interested in the rod between the ps gear box and the front axle. how much shipped to elberton ga 30635 ?
09-04-2020, 09:50 AM | #30 |
Not sure which one you're talking about. In this pic there's the Pitman arm, some other rod with tie rod ends on it, and another arm bolted to the knuckle. I can tell you the "tie rod part" is homemade.
09-04-2020, 05:02 PM | #31 |
I hesitated to call it a tie rod because I knew it had to be homemade. I have a 68 Suburban with closed knuckle front end that I'm trying to add power steering to. Does it look cobbled together or like somebody did a decent job?
09-05-2020, 10:14 AM | #32 | |
SOLD Last edited by VictoriaHardware; 09-08-2020 at 04:31 PM. |
09-11-2020, 06:47 PM | #33 |
Parts arrived today. Well packed and in the condition depicted.
Thank you
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ My GMC Photos |
09-11-2020, 08:38 PM | #34 |
Got the mounts, thanks. Do you have this brace?
09-12-2020, 09:17 PM | #35 |
I assume you're talking about the crossmember. It's heavily rust pitted and has part of a trailer hitch welded to it. It also got chunks cut off when the rest was cut with a torch. So it's not better than what you have now.
09-13-2020, 04:56 PM | #36 |
Parts remaining- prices plus shipping & PP fees
Axle, front $200 '65 Dana 44 Closed Knuckle, 3.73, open carrier, 6 lug, excellent condition, no shipping Axle, rear $50 SOLD '65 3.73, open carrier, 6 lug, fair condition, no shipping Transmission $200 SOLD '69 SM465 4 spd, no shipping Cylinder Heads, 3932441 $100 SOLD Both dated A-9-9. bare castings Steering Gear w/ pitman arm $125 Integral box, '69 (?) Last edited by VictoriaHardware; 10-04-2020 at 12:39 PM. |
09-13-2020, 05:00 PM | #37 |
Crossmember $75
K10 manual transmission, with spring mounts and hardware Lift blocks $50 SOLD cast iron, rear axle, with clamps Jounce Bumper Blocks $25 cast iron, front axle Spring Mounts $25 ea SOLD Front - forward LH, forward RH Rear - forward LH, forward RH, rearward RH Last edited by VictoriaHardware; 10-20-2020 at 10:12 AM. |
09-13-2020, 05:01 PM | #38 |
Brass Fittings- $25 SOLD
brake plumbing, 4 pcs Clutch Linkage $25 Frame bracket, cross shaft, Rod, Lever w/ Hardware Last edited by VictoriaHardware; 09-20-2020 at 07:46 AM. |
09-13-2020, 05:25 PM | #39 |
09-15-2020, 07:33 AM | #40 |
How bad are the suburban/panel/carryall specific rear frame pieces, or do you still have them at all?
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778 Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775 |
09-15-2020, 08:59 PM | #41 |
09-15-2020, 11:17 PM | #42 |
I will take the brass fittings for brake lines.
09-16-2020, 04:01 PM | #43 |
How are the front horns, what price are they? I will take depending on price.
Cut behind the motor mounts and include radiator crossmember. Send photos please of frame as is now. Price on the front spring Mounting brackets, will take pending price. Price for rear spring shackles front and rear, will take pending price. Will you take 100 for the five of them? Last edited by aotte1; 09-16-2020 at 04:56 PM. |
09-16-2020, 04:34 PM | #44 |
I will take the transfer case shift linkage pending price/shipping.
Photo of needed parts circled in yellow. All except pins in TC. |
09-16-2020, 08:45 PM | #45 | |
Rad crossmember- pics tomorrow Rest of frame - pics tomorrow Spring mounts- $100 for 5 is OK Transfer case & all associated parts are already sold |
09-16-2020, 09:03 PM | #46 |
I will take the 5 spring mounts. Maybe ship in large Usps flats rate box.
Ok if wait, to pay until we finish if getting additional parts after tomorrow Pictures. Thanks, |
09-17-2020, 12:04 PM | #47 |
Rad crossmember- Some rust, couple nicks from the torch, but very usable. Truck had never been in an accident so part is straight $20
09-17-2020, 12:06 PM | #48 |
Frame horns- cracked & bent, some rust $20/pr
Rest of frame - Sad picture. Valued @ $.50 in scrap steel |
09-17-2020, 04:47 PM | #49 |
Thanks for pictures:
Will take the front frame horns. And left front frame rail sections circled in yellow. Will confirm with you frame rail needEd on left side with engine mount in more detail. Do you have frame right side engine mount/perch? Will take if you have too. Also in second photo, do you have both side of rear frame circled in yellow? Third photo below do you have the body mount circled both side? Last edited by aotte1; 09-17-2020 at 05:10 PM. |
09-17-2020, 08:55 PM | #50 | |
Next LH frame section is not bad rust-wise. Factory engine mount is good. Truck was originally a 292 six. RH engine mount is not original- see bolts. A 350 V8 had been transplanted and the RH engine mount did not fit correctly. In fact the RH side of the engine was held in by gravity, so I don't think this will be of any good to you. |
