11-25-2020, 11:50 PM | #26 |
Old member
Re: Push Brake Pedal and right turn signal comes on???
Glad you figured it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-26-2020, 11:26 AM | #27 |
Thanks Andy
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-24-2024, 01:06 PM | #28 |
This is an old thread, but just wanted to pass on some information with this very problem. I swapped out steering columns as stated above my right turn signal would come on with the brake pedal being pushed. What I found was that my turn signal switch was tightened down very tight to the point that the plastic turn signal was slightly warped. I didn’t notice until I started troubleshooting this issue. Long story short, I had to back out each bolt until I found the one that was tightened too far down causing the grounding issue. This solved my problem.
Thank you all for this site, it is a life saver!
