Old 12-03-2020, 01:30 PM   #1
hemi43
hemi43's Avatar
Re: 1970 Blazer Granny Gear
Originally Posted by K5Fan View Post
That's next on the list.
A friend of mine who I did some work for is giving me a complete running 2008 Tahoe LTZ (4X4) with the 5.3L motor, and overdrive tranny, so I will see what I can do with that.
2008 is not the best for conversion. Not saying it's bad, it's just the 08 has displacement on demand and it uses an ECM and a TCM unlike the older engines (07 classic and older) with just a PCM controlling the engine and transmission. If you're going to use the 08, I would change out the lifters and disable the displacement on demand and run an aftermarket computer.
FWIW, 2002 is the best donor IMHO because it's the last year for drive by cable. 2003-up uses drive by wire which works fine, but gives you a horrible pedal feel which can't be changed using the factory computer.
hemi43 is offline   Reply With Quote
