Old 12-04-2020, 10:45 AM   #26
chevykevy
chevykevy's Avatar
Re: 66swb
What do you estimate your front and rear drop is? And....did you go with 16” wheels to help clear front lower control arm from hitting a drop spindle?
chevykevy is offline   Reply With Quote
Old 12-05-2020, 02:46 PM   #27
PNW'65
Re: 66 SWB Fleet
Originally Posted by Ghetto Fireman View Post
Finally done !
Gauge cluster restored and tach/vacuum gauge added by Redline Restoration
Could you give some more detail here? It looks great and I'd like to do something similar.
I'm not familiar with redline resto, and some preliminary googling turned up a few small shops.
PNW'65 is offline   Reply With Quote
Old 12-05-2020, 09:42 PM   #28
Ghetto Fireman
Junior Member
Ghetto Fireman's Avatar
Re: 66swb
3/5 static drop. I used 2 1/2” drop spindles from CCP along with a 1” drop coil. Yes, 16” cleared LCA. Needed to grind a bit off LCA see the outside edge of the rotor.
Ghetto Fireman is offline   Reply With Quote
Old 12-05-2020, 09:44 PM   #29
Ghetto Fireman
Junior Member
Re: 66 SWB Fleet
Redline gauge and clock
www.redlineg.com
Old 12-05-2020, 10:38 PM   #30
Ghetto Fireman
Junior Member
Re: 66swb
Originally Posted by Vortech View Post
Ghetto Fireman, with regards to the Lokar accelerator pedal, which one did you install. The one for 67-70 or the one for 71-72. In any case any close up pictures of the install. thanks
I picked up the Lokar pedal some time ago, if I remember correctly it’s 67-70. Let me go through my paperwork see if I can find it.
67-70, bought it in 2016.
Old 12-06-2020, 10:16 AM   #31
chevykevy
chevykevy's Avatar
Re: 66swb
Thanks for the wheel and suspension info.
How about steering?��.....I see you have the period idler arm and also have power steering.
Are all of your steering components from 65 Such as centerline, inner and out tie rods, or is it a mix of late model as well?
Sorry for all the questions but I’m hoping to do many of the same Upgrades .
Old 12-06-2020, 10:47 AM   #32
Ghetto Fireman
Junior Member
Re: 66swb
All new period correct (66) Moog replacement steering components. I went with Vintage Air serpentine Frontrunner system, which comes with alternator, water and power steering pump. Ididit column. 2 1/2” drop spindles from CCP.
Old 12-06-2020, 05:30 PM   #33
SCOTI
SCOTI's Avatar
Re: 66swb
Your avatar image looks like the truck has some caps now. Is that from previous or have you made changes?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-06-2020, 06:36 PM   #34
Ghetto Fireman
Junior Member
Re: 66swb
Yup, old photo. Current as she sits now
Old 12-06-2020, 11:10 PM   #35
Ghetto Fireman
Junior Member
Re: 66swb
It’s great , exhaust is routed through the frame, just a simple down turn after the mufflers. Does kick up a lot road dirt.
Here’s a photo, exhaust is now ceramic coated.
Old 12-07-2020, 12:45 AM   #36
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: 66swb
Good Looking Truck Ghetto Fireman..
Stance is Killa..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
