Active Member
![]() Join Date: Feb 2017
283ci Bracket Question
Anybody put headers on their stock 283 (1967 C10)? If so what did you do for the alternator bracket that bolted into the original exhaust manifold? My truck still has the factory heads that are not tapped for brackets.
And yes I know, I know! Just drop a 350 in it or just change the heads, but I just don't have the funds for that right now, but I do have a set of headers in the shop I can put on it. Thanks guys! |
Who Changed This?
![]() Join Date: Jan 2013
Re: 283ci Bracket Question
I don't recall what the setup looks like, but when I put headers on the 305 SBC I had in my '68 Skylark, I used a 1/2" pipe nipple with a washer to space the bracket out, as the header flange was thinner than the manifold. The engine had tapped holes in the head, but I don't recall if I used them. Let's see a picture of what you have. Someone will certainly have a solution.
Active Member
Will try to snap a pick next week and get it posted. My heads are not tapped for any accessories at all. Wish I had the money to just drop a crate 350 in it.
#4 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I used Summit SUM-G4050 ($7.99) and SUM-G4051 ($8.99) brackets, which mounts the alternator on the LH/driver side. They are offered in both chrome and black, and mount to the #1 cylinder header bolts, not the head.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 12-13-2020 at 12:29 AM. |
Active Member
Thanks a lot. Those will be perfect.
I would keep the original rams horns, but they are rusted thru so I'll have to use what's available at the moment. |
#8 | |
Old member
![]() Quote:
Well by the time you change the exhaust piping to work with the headers and pay the exhaust shop + buying the new brackets, you can replace the ram horns with some used ones and be back up running at the house without a trip to the exhaust shop. ![]()
Active Member
Good point Andy. I did not think about that.
![]() Join Date: Aug 2019
Some of us old hot roders just like headers.
