#26 |
Re: Fuel line recommendations
[QUOTE=Wasted Income;7043992]I got da clap from a long drunken night in Nogales, MX.
I What do you "remember" about Calle Cannel]
#27 |
I have to revive this old thread.
I'm using aluminum 3/8 fuel and return line for my EFI. How do I go from the straight 3/8 hard line to a -6an fitting? Part #s if you have them please. Thanks |
#28 |
#29 | |
Pardon me for this but I want to make sure I get it right. I read that no flare is required for this fitting, true? Will this handle High PSI? I believe my intank pump delivers at 100 psi. |
#30 |
Yes, this compression style adapter fitting can be used in EFI applications - up to 250 PSI.
Earl's Performance AT165006ERL uses a compression fitting to lock onto a 3/8 inch outer diameter smooth tube. If the tube you are attaching this to has a barb or a nipple on the end to help hold on a hose, you will need to use a tubing cutter to remove that nipple. Once you have a smooth tube you can slip on the nut and the feral and tighten it down. |
#31 | |
I've been searching for this answer. I originally was going with a carburated setup but switched to EFI. I already bought the 3/8 aluminum tube and didn't want to have to buy braided lines all the way back to the under bed tank. You just saved me a bundle, merry christmas. |
#32 |
Np my friend. Merry Christmas to you and yours as well!
#33 |
Sorta off the subject, but relevant to the thread title...
The fuel rails on these engines can be turned around 180 degrees. This puts the fuel inlet on the passenger side facing forward. I'm going to be running 3/8 stainless hardline on the inside of the passenger side chassis. This hardline will be terminated in a -6AN tube sleeve and nut, and a 37 degree flare. I'm using a -6AN (or JIC, they're the same thing) bulkhead elbow fitting. This will go up through the top flange of the chassis, and a locknut is installed to secure it to that top flange. From here, it will be a quick simple hop with AN hose up to a fuel rail adapter fitting on the fuel rail itself. Routing the hose this way keeps that flex hose up near the front of the engine where it's easier to access for inspection and replacement. I won't have to be digging around on the back of the engine, trying to unbolt a fuel hose clamp from a bellhousing bolt. Keep in mind that this is on a 4wd truck. It's possible the 2wd trucks don't have a clear spot on the chassis in the right spot to install that bulkhead fitting.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#34 |
I have not run fuel line yet
I am looking at nylon fuel line many factory rides have nylon fuel line Might even mix it with steel lines Going to see how my parts truck lines are run This is an example Summit has Dorman lines and fittings https://www.amazon.com/Inline-Tube-N.../dp/B07NQTG3DL |
#35 |
If you're intending to run nylon line up the back of the engine, make sure your engine is far enough forward to do so comfortably. Mine is not. I put the LS into the stock position(14" from bellhousing to rear of clamshell) on a squarebody truck. It's within an inch of the firewall.
#36 |
I am thinking use the factory flex line going up the back of the motor
Depends on how its joined and shape of it Yes nylon lines need long slow bends not sharp tight bends |
#37 |
![]() Join Date: Nov 2013
I used Summit teflon braided lines from the tank to 3/8" aluminum hard lines inside the driver side frame rail to the filter...
then teflon braided again to the pressure regulator...... then teflon from the regulator to the fuel rail I flared the aluminum for 37º -6 AN fittings using Eastwood turret flaring tool put a junction here in case I need to drop the tank ordered some industrial tube clamps to secure the hard lines Aeromotive replaceable filter housing (not as close to the exhaust pipe as it looks in the picture) teflon braided lines to the Aeromotive regulator Fabbed a bracket to bolt to the head
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
