Old 12-29-2020, 11:15 PM   #1
regan56
Tie rod and steering linkage
Anybody have photos of their straight axle and tie rod / steering linkage? I had pics of mine before i took it apart, but I lost the pics. Now I’m trying to reinstall the pieces but I can’t recall how the go back together.
If you have pics that would be great! Bar to the back of the axle? Connect to the top of the spindle?
regan56 is offline   Reply With Quote
Old 12-29-2020, 11:36 PM   #2
nvrdone
Re: Tie rod and steering linkage
dont have pics but maybe i can help. if your truck is an AD series and has a stock I beam axle, the steering arms bolt to the lower mount on the spindle. There should be 2 long bolts with spacers between the steering arm and spindle. the top curves over the top of the spindle, the drag link goes between the top of the spindle arm and the steering box arm. The right arm bolts on to the spindle the same as the left one. both arms point to the rear. If you have a stock tie rod, that bolts on to the balls on the lower end of the spindle arms.
If the system has been modified in any way, then thats a whole new ball game. More detail on what you are working with would help.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 12-29-2020, 11:44 PM   #3
regan56
56 GMC 2nd series.
Stock steering and straight axle. Only thing that’s different is the new style tie rod ends.
Old 12-30-2020, 12:36 AM   #4
nvrdone
ok, it should go together like the AD's.
Old 12-30-2020, 12:47 PM   #5
57tailgater
I recently got this setup and it was on a '58 GMC but '55.2-59 Chevy and GMC 1/2 ton will be the same. These are the stock tie rod ends but the new style would be installed the same orientation.
57tailgater is offline   Reply With Quote
Old 12-30-2020, 12:54 PM   #6
regan56
Those spacers, they about an inch long? I have 4 in my parts bin that are this length.
Old 12-30-2020, 12:56 PM   #7
regan56
Excellent!! Thank you for the pics. I’m sure you would have posted if you did but you wouldn’t have pics of the backside of the drivers side hey? Showing the u-shaped piece?
Old 12-30-2020, 01:06 PM   #8
1project2many
If you don't have it, there is a copy of the FSM online here. Steering and Suspension is in Section 3.
1project2many is offline   Reply With Quote
Old 12-30-2020, 02:26 PM   #9
regan56
Great link. Thank you.
Maybe I didn’t see it but I still don’t know how the driver side goes, although it may just fall into place once I get going . Also the four spacers I have are 1.5” long but the only one I have that are big enough to accept the proper size bolt to fit the steering arms so process of elimination tells me these are the ones referenced by nvrdone.
Also, the link that was posted makes reference to a stabilizer bar? I don’t have one for my truck, so not sure if it was removed prior to me getting it? Or I just don’t recall removing it, but I certainly would have kept it if I had?
Old 12-30-2020, 03:58 PM   #10
regan56
Ok I’ve mocked up my linkage and something is off here?
Old 12-30-2020, 04:29 PM   #11
nvrdone
looks like you have the arms on the wrong side. the top of the left arm curves back over the king pin toward the frame with the drag link pointing back and hooking to the steering box. the tie rod goes behind the axle under the spring.
im sure many of us have made this kind of mistake. thats how we learn.
Old 12-30-2020, 05:28 PM   #12
regan56
Ball joint facing down though? (Bolt/nut side down)
Old 12-30-2020, 05:52 PM   #13
G&R's57GMC
G&R's57GMC's Avatar
Here's what you're looking for ...
Right of pic's is to the front ...
1st Drivers side
2nd Passenger side
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 12-30-2020, 07:34 PM   #14
regan56
1st Drivers side
2nd Passenger side
Excellent. So no spacers???makes sense. The way I have it laid out theses no way I can see the spacers working.
Old 12-30-2020, 08:12 PM   #15
mr48chev
mr48chev's Avatar
If it takes spacers the spacers will go between the spindle and the backing plate rather than the spindle and the steering arms.
This a shot of my muddy mess under my 48 that I took years back and you can see the spacers between the spindle and the 54 Chevy car backing plates. The truck backing plates didn't need spacers on one pair of bolts but did on the other.
This is the passenger side. I'd think if those spacers were used on it it was because someone swapped backing plates.
My ongoing truck projects:
Old 12-30-2020, 11:08 PM   #16
dsraven
I was gonna say the spacers go between the backing plate and the spindle. it's been awhile though.
Old 12-31-2020, 11:12 AM   #17
nvrdone
sorry for the incorect info. yes, the spacers go between the backing plate and spindle on the lower bolts.
Old 12-31-2020, 12:58 PM   #18
regan56
No worries. Lots of more good information here.
I will have more questions on this as I work through.
Regarding the sway bar question though, was it not std equipment back in the day? It’s easy enough to add now by the looks of the kits but is it something I would notice? I’ve never had a truck without.
Old 12-31-2020, 01:18 PM   #19
dsraven
Putting around town you may not notice unless you like to do quick cornering. Fast speeds with corners is where you will notice body roll.
Not all came equipped but not a bad idea to have one if available. Google 55-59 chev factory assembly manual and the tri5 site should come up with one that you could download for future reference. It shows how it was put together.
Old 12-31-2020, 01:37 PM   #20
mr48chev
mr48chev's Avatar
Correct. You can see the spacer between the spindle and backing plate in G&R's57GMC's photo of the left spindle.
I don't know why you would put those long spacers between the spindle and steering arms unless in a previous life that axle had real wide tires and wheels with a lot of positive offset and needed to have the tire rod ends clear the tires and a pretty suspect modification to do it.
Old 12-31-2020, 03:27 PM   #21
_Ogre
_Ogre's Avatar
i believe the sway bar was stock on the suburban only
my 59 panel did not have a sway bar, nor any of the tf pickups i've owned
shop air compressor timer
Old 12-31-2020, 04:17 PM   #22
nvrdone
my '49 didn't have front or rear bars. I added a front bar from Brothers and a rear bar from my grand cherokee ( I up graded to SRT 8 bars). The truck handles much better but no where like a Vette etc.
Old 12-31-2020, 09:30 PM   #23
mr48chev
mr48chev's Avatar
I looked in the GM Heritage center archives and it doesn't show accessories for 48, 49 or 50 but in 51 it does show a Ride stabilizer. That may have been an upgrade with the tube shocks.
Old 01-04-2021, 12:15 PM   #24
frkennyg
I am working on a 1957 Chevy truck. I do have pics that will help you. Unfortunately my limited computer knowledge keeps me from posting them. I have all new parts that are the original with updated tie-rod ends. Let me know if you still need the pics.
frkennyg is offline   Reply With Quote
Old 01-04-2021, 03:19 PM   #25
G&R's57GMC
G&R's57GMC's Avatar
The Pic's I posted are an unmolested 55-59 Chevy half ton .
The spacers go between the backing plate and spindle .
And No anti sway bar was offered standard or optional , The aftermarket offers them today for both front and rear .
The aftermarket also offers a steering stabilizer kit that bolts onto brackets on the axle and tie rod that a 50 50 shock mounts to , all included in the kit .
Glen & Jane's Rides
