01-17-2021, 03:05 PM | #1 |
70 Jimmy 4x4 driveline upgrade
So I’m going to upgrade the drivetrain on my Jimmy. Currently it has a tired leaky 350, a very leaky th350, and leaky 205.
I have opportunity to replace the 350 with a gm crate engine around 400hp. & I’d have the 205 gone through and resealed. My Main question is the transmission. Rebuild/beef up the th350, replace with new th350 or swap to 700r4 for the overdrive? (When I swapped the 2 speed for a 200r4 in my 68 firebird it was pretty much just change Xmember and setup tv cable and lockup switch. Not sure on dimensions or what else is involved in changing to a 700 and if it’s worth it. I looked through posts but a lot are older and apply to 2wd trucks etc, so figured I’d ask again. This is not a daily driver but an every so often weekend cruise around vehicle. Of course the more I do to it, the more I want to drive it. I just started really messing with it again this past year or 2 after mostly sitting in the garage for over 12 years. I put a hydro boost brake system, brakes, 33” tires, soft top and dash stuff so far. I have 2.5” springs, shocks, and stabilizers waiting to go on so some progress is in the future. Last edited by k-nuts; 01-17-2021 at 03:23 PM. |
01-17-2021, 03:32 PM | #2 |
Re: 70 Jimmy 4x4 driveline upgrade
Here are a couple of threads to get you started:
http://www.67-72chevytrucks.com/vboa...ht=700r4+np205 http://www.67-72chevytrucks.com/vboa...ht=700r4+np205
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-17-2021, 04:54 PM | #3 |
Carpe manana
I’ve got a th350 in my Blazer and a 700r4 in my K20 with 3.73 and 4.10 gears respectively: both with 350 sbc and 33” tires. The Blazer with that driveline/tire combo drives fine to 60-65mph. The k20 with 700r4 will cruise nice at 75mph. There is very little clearance at the front shaft yoke in the k20.
I recommend keeping a th350. It’s not worth the hassle and added expense to swap in the 700r4. If I were to redo my k20 I’d likely make use of a th350 with a gear vendors overdrive. My Blazer has its original drivetrain and my k20 has a correct 350 or I’d have entertained an engine swap.
01-23-2021, 12:19 AM | #4 |
There’s also a semi local low mile (<40k) 2016 Sierra 6.2L Complete pullout w 8L90E and xfer case for 5500.
I know the xfer case won’t work, but this is another option that obviously would require more work but actually Maybe less expensive in the long run from my first plan. Thoughts? I don’t want to experiment to see what fits and what works. I want to know what i need and order it. 😁 |
01-23-2021, 11:33 AM | #5 | |
I always tell people looking to swap to a later model engine/transmission to use a 2002 5.3. 2002 was the last year of drive by cable, and the factory computer is easy to hack. The problem is that those engines are getting difficult to find with low miles. |
01-23-2021, 12:02 PM | #6 |
Thanks for the all the replies. Just can’t decide which way to go. But good to know about the newer computer systems. I though they all could be easily flashed or whatever it’s called. I don’t want this to be an ongoing upgrade that takes forever to get back in road.
I ran my ‘02 6.0 to 300k before selling my 2500hd. So I know those engines can run forever but rather not gamble on a high mile pull out. Another option is the EFI version of the GM 350 crate engine I was looking at. Just don’t know if the extra expense is worth it? I think I would just need fuel pump and return line (so a new tank?) |
01-23-2021, 09:49 PM | #7 |
You might want to watch this before going with that transmission:
https://www.youtube.com/watch?v=QGA44xKGLpU
01-24-2021, 04:56 PM | #8 |
Ya. I have one In my 19 Sierra now. Has a couple jolts when going from reverse, stop and shift into drive. Dealer says “can not duplicate” problem. Because it’s random and not very often.
As far as the Jimmy goes I’m leaning back at the gm crate engine and rebuilding (beefing up) the th350. |
01-24-2021, 05:29 PM | #9 | |
01-24-2021, 08:50 PM | #10 |
01-24-2021, 09:24 PM | #11 |
01-29-2021, 11:57 PM | #12 |
Deadhead I am wondering what you did about driveline angle? Mine is just about done and I keep looking at how steep the driveshaft is. I went with the 350 and a 700 r4 with an np 208. Dropped the trans mount about 3” tilted the rear ended with angle shim as much as I dared and even welded the axle perches on at a different angle. It is a steep angle for sure for such a short shaft. I can’t Rene eat the angle but will recheck.
01-30-2021, 08:57 AM | #13 | |
Carpe manana
Recently a member added a gear vendors overdrive to his K5 and commented on the driveshaft angle and what was done. I’ll dig for his post and edit it onto this post when I find it. EDIT: see post #10 here http://67-72chevytrucks.com/vboard/s...d.php?t=814872
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 01-30-2021 at 12:26 PM. Reason: Added |
01-30-2021, 11:57 AM | #14 |
Sorry didn't realize yours was a lwb. Mine is in a blazer with a 4" lift seems pretty steep
