01-31-2021, 01:42 PM | #2326 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Can’t figure out if you’re a bad influence or a good one I did figure out that the posi is definitely working and here’s proof
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-31-2021, 01:44 PM | #2327 |
A guy with a truck
Agree. I’m not sure I’d buy them even if I had $4k burning a hole in my pocket, but I’d love to be in a position to have to make that decision
02-01-2021, 10:44 AM | #2328 |
Man this bus is getting crowded....
02-01-2021, 11:21 AM | #2329 |
In the long run, does it really even matter?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-03-2021, 10:37 AM | #2330 |
I think you should make the decision for those wheels, they would look awfully nice and something a little different for that beautiful truck. Kind of remind me of the old Halibrands. N2Billet does make all the mods look easy.
02-03-2021, 10:43 AM | #2331 |
02-03-2021, 10:44 AM | #2332 |
Sorry about the double post!
02-03-2021, 05:10 PM | #2333 | ||
A guy with a truck
02-03-2021, 05:56 PM | #2334 |
Wait..... OUR great-grand-uncle is still alive? Praise the lowered!
02-03-2021, 07:53 PM | #2335 |
A guy with a truck
If his money ever comes through, I’ll buy you a beer. A big one. Matter of fact, next time I see you, inheritance or no, beers are on me
02-03-2021, 07:56 PM | #2336 |
Does that only apply to SCOTI?
02-07-2021, 01:01 AM | #2337 |
Chris, love the wheel choice for when its fiscally possible. I get it about wheel & tire cost. I'm in the process of upgrading the wheels & tires on my Sierra. Its got the ugly steel 17's with the holes & I've looked at all sorts of OEM stuff & really have it bad for the '16-'18 Tahoe 5 spoke 20s...just can't afford them. I did settle on some Titan/Armada 5 spoke 18's...cheaper, but they are still moderately pricey with the tires. Btw, I really dig the burnout picture...just need to follow Mcbassin's lead and do some filming of the next loss of traction episode
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 02-07-2021 at 01:09 AM. |
02-07-2021, 01:33 AM | #2338 | |
And I'm surprised you could see your hoops. Your truck is lower than mine too, what you do lay on the ground? LOL. You can see mine but only if your way back(and that far back you really can't see actually) or you take a knee behind truck. I'm curious, air cleaner looks real good, what color IS your favorite shade of vht?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
02-07-2021, 11:47 AM | #2339 | ||
A guy with a truck
No way, we’re definitely having some beers soon
02-07-2021, 01:13 PM | #2340 |
I've taken some ideas from you, so glad I could at least send a nudge over man. Cheers.
Hey, curious, what psi are you spraying your TCP Global SS? I will be spraying my truck for last time in a couple months and want to get it right. .
02-07-2021, 10:19 PM | #2341 |
A guy with a truck
I think I ended up around 16-18 at the gun using the HF purple throw away. YMMV
02-13-2021, 10:18 PM | #2342 |
A guy with a truck
Finished up the rebuild of the doors, including the installation of the Altman latches on the pass side, new weatherstripping, felts, scrapers, and vent window seals. While the door panels were off, I decided to go ahead and add the side mirrors I’ve been putting off installing for the last 15 years. The arms and gaskets seem like decent quality, but the backing plates needed one of the threaded nuts moved and the heads are loose out of the box. Not sure I particularly like them, but the holes are drilled and they’re installed, so....
02-13-2021, 10:35 PM | #2343 | |
02-15-2021, 08:11 PM | #2344 |
A guy with a truck
Working on getting the bed floor in place. Requires building a framework to clear the notches and lay the planks on. Figured the easiest way was welding up some angle iron, but had to poke some holes in the floor to be able to reach the nuts on the underside of the carriage bolts. This thing will go together like a puzzle and hopefully stay together for a long time (famous last words)...
02-15-2021, 08:40 PM | #2345 |
Looking good! I really like how your truck is coming together. Has a very nice "Feel" to it. I am considering doing the flatter paint as well when I get there.
02-19-2021, 04:14 PM | #2346 | |
A guy with a truck
More minimal progress; finished up welding/bolting in the sub floor braces and started poking holes for the strips. Next up is getting the wood and tubs in paint...
02-19-2021, 04:52 PM | #2347 |
Looks very clean & simple. Your efforts show....
02-19-2021, 05:44 PM | #2348 |
67-72 parts collector,…
You make this stuff look easy.
02-20-2021, 09:05 AM | #2349 |
It Is What It Is
Looks very nice, Chris. Gonna be beautiful when you are done.
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
02-20-2021, 11:43 AM | #2350 |
Where did you get the inner wheel tubs? Or did you make them? Thanks.
