01-15-2021, 03:51 PM | #1476 |
Re: 53 Surburban "Family Truckster"
Marc omg that seat! Wow!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-15-2021, 04:13 PM | #1477 |
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-17-2021, 10:03 PM | #1478 |
Today I worked on some odds and ends. My license plate mount was crooked (my fault) as seen in the pic and it bugged me. I cut it apart to reweld in an effort to straighten it out. (no pics of the correction).
I also tapped in to my running light feed to power the license plate lights. Since my license plate mount is basically a hitch receiver inset I needed to be able to unhook the wires that power the license plate lights. For this I purchased a 2 wire water tight connector off of EBay. This way when I remove my plate to inset the hitch I can unplug the power supply. For a clean solution I choose to use the license plate LED bolts. I used the same thing on my 48 and they also worked great. I will mount them at the bottom of the plate shooting up. Marc
01-17-2021, 10:18 PM | #1479 |
Dome Light LED upgrade.
I figured there might be some interest in this upgrade, so I broke it out on its own page. I removed the OEM light socket from the housing. I purchased a 24 light LED panel (Found on Ebay for $7.00). This will put out a lot of light. You can also get smaller panels like 18 light ect. I added longer power and ground leads to the LED panel. I also added a 2nd dome light in the roof of my suburban for adequate lighting. You can use whatever you like to secure the LED panel to the housing. I used 3m strip caulk that I balled up as I had some laying around. The panel is feather light so you could really use 3M double sided tape or hot glue. With the frosted glass light lens, you don't see the LED panel or black strip caulk. I also used some more strip caulk to create a gasket around the wired exiting the housing. Any ??'s please ask but its fairly straight forward. Marc
01-17-2021, 10:24 PM | #1480 |
I like the Interior light mods...that should work great
01-18-2021, 11:30 AM | #1481 |
License plate and interior lights are great idea I'm going to have to steal this from you.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
01-18-2021, 11:36 AM | #1482 |
Great idea...
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
01-18-2021, 12:22 PM | #1483 | |
Thanks Mongo..
Thank you Marc
02-06-2021, 01:17 PM | #1484 |
lots of great ideas...roger
02-07-2021, 01:52 AM | #1485 |
I know SQUAT about LED's. I assume since you didn't mention it, they use full 12v power?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-08-2021, 09:12 AM | #1486 | |
Thank you Roger..much appreciated.
Marc
02-08-2021, 11:52 PM | #1487 |
Thanks Marc - for your explanations to some with "lame-old-dude-itis"!
If you've posted it maybe I've missed it but whose door switches are you using? I've heard all sorts recommended makes.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 02-09-2021 at 12:02 AM. |
02-09-2021, 09:08 AM | #1488 | |
Similar to these. Nothing fancy. You can also get some with plastic/rubber end caps. https://www.summitracing.com/parts/prf-80170 Thanks Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 02-09-2021 at 09:14 AM. |
02-12-2021, 01:09 PM | #1489 |
6>8 Plugless........
I really like the LED upgrade! I added 3rd brake lights to the cargo lamp on my 72 and now wish I would have done something like this for the cargo lamp. Did you add the frosted finish to the lens? I've been wondering id media blasting them is a sufficient way to accomplish that?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-12-2021, 04:17 PM | #1490 | |
Thanks mam..... No the lens is frosted from the factory. It's an OEM glass lens. They sell rattle can paint to add a frosted look. I bet you could spray the inside of the lens. That way it would still look glossy from the outside. LED's don't put out any heat so I bet it would hold up fine and might be a better option than blasting the lens. Just keep applying light coats to get the desired amount of frosting. Just a thought (outside the box) Marc
02-13-2021, 10:53 PM | #1491 |
On Friday night I started fitting and working on my lower dash panel my friend Zach made for me. The first picture I taped on the AC vents to get an idea of placement. I then cut in holes for the vents as well as the AC controller as well as the wiper and light switches. This is the last part that needed to be modified before I get it painted to match the rest of the dash.
As a refresher this panel is the reason I cut my dashboard straight across on the bottom. I did something very similar on my 48. I like to utilize this lower panel to keep the main dash free of switches and knobs.... Thanks Marc
02-14-2021, 10:20 AM | #1492 |
Very nice look on the dash.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
02-14-2021, 10:24 AM | #1493 |
Marc, looks good, like the placement...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-14-2021, 10:29 AM | #1494 |
Thanks guys....
Marc
02-14-2021, 12:57 PM | #1495 |
Looks great
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
02-16-2021, 03:41 PM | #1496 | |
D'Oh ! not sure why, but don't let this happen to your door switch
02-16-2021, 04:42 PM | #1497 | |
Thank you
Marc
02-16-2021, 04:56 PM | #1498 |
ya, I think you are right, it sticks out too far.
The funny thing is it still works fine.
02-16-2021, 06:41 PM | #1499 |
If it works it aint broke
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
02-17-2021, 03:12 AM | #1500 |
Nice touch. It will hide the ac pipes as well.
