02-23-2021, 03:12 AM | #1 |
Active Member
Got The Bed Off - Gas Tank Install Next
Moving slowly, but finally got the bed off. I was expecting the frame to be rusted badly, but was pleasantly surprised at the lack of rust. I mean it still has some rust but not too bad. It looks shiny cause it was still wet from washing the dirt and mud off of it. Now time to install the new gas tank when it arrives, and springs and shock relo brackets, and rebuild the rear end.
02-23-2021, 11:33 AM | #2 |
Re: Got The Bed Off - Gas Tank Install Next
How difficult was it to get the bed off? I am currently starting the process of replacing my rockers. I would like to pull the bed and undercoat it along with cleaning the frame up and painting it, I just didn't want to bite off more than I can chew.
02-23-2021, 12:09 PM | #3 |
Active Member
It wasn’t too difficult. I did it by myself. I built some wooden perches to attach the bed to and used hydraulic jacks to Jack it up a bit at a time. Very dangerous so use great care. When I’m ready to do the bed I’ll roll a trailer underneath it and lower it back down so I can move it around or either I’ll disassemble it where it is. I do not plan on getting under it as it sits now.
02-23-2021, 12:12 PM | #4 |
Active Member
Sorry my photos are sideways. I can engineer the removal of a bed, but getting a photo oriented the right way is a challenge.
02-23-2021, 12:22 PM | #5 | |
Thanks for the response. |
02-23-2021, 12:26 PM | #6 |
Active Member
I went up a few inches at a time on each corner. The bed is heavy and extremely awkward so it want to shift around at times. Once I had it higher enough I just rolled the truck out from under it. Please do not get under it if you block it up like mine. Would hate for it to fall on you.
02-23-2021, 03:21 PM | #7 |
Who's rear mount fuel tank are you going to use?
I open my photos in Paint, make sure they are oriented correctly, and resave under another name. That is the only way I have found to make sure they insert correctly.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
02-23-2021, 03:24 PM | #8 |
Active Member
I am going with Boyd’s Welding side fill tank. It’s expensive but high quality from what I hear.
02-23-2021, 03:29 PM | #9 |
Pulling the bed itself isn't super hard. Getting to the point where you can pull it is a totally different story depending on how rusted the mounting bolts are. The truck in my avatar pic was brutal. I think I had to cut every bolt.
02-23-2021, 04:30 PM | #10 | |
Have taken 2 beds off in last year. Completely disassembled one bed... THere's eight 3/8 carriage bolts holding bed to frame. THe nuts WILL come loose. BUT, and that's a BIG BUT, they will get hung up on what's left of the bolt threads below the nut. THe bed carriage bolts are not as bad as the bedside and front pan bolts are. Next time a cut off wheel will be used to remove the threads hanging below the nuts on ALL the bed bolts!!! |
02-23-2021, 04:30 PM | #11 |
If your using a phone, always hold the phone sideways for pics you want to upload. Or you can open them in ms paint and resave.
