02-21-2021, 08:02 PM | #26 |
Re: Were did you find you build sheet?
I've only found one complete build sheet, and that was in my '89 Grand Marquis, and even then, had I not looked, the vacuum cleaner would have taken most of it. My '83 and '81 trucks had no build sheet at all in the seats. My '73 Nova had a partial sheet under the carpet, like keith mentioned, sprayed over mostly with tar. The old '76 winter beater also had no build sheet anywhere front to back.
02-21-2021, 09:48 PM | #27 |
Bottom of Seat springs 75 made in Canada missing most it faded out. It's pretty blank now.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
02-24-2021, 09:33 AM | #28 |
Found this while looking for something else.
It's kind of a re-hash of what we've already discussed here, but the information is presented in a bit different way: http://67-72chevytrucks.com/vboard/s...t=paper&page=4
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-24-2021, 09:34 AM | #29 |
This is what I was looking for:
GM most technologically advanced vehicle (at the time, and perhaps still now) - still built with a piece of paper taped to the front of the car - This happens to be the first 2013 model year Volt, in Detroit-Hamtramck. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-24-2021 at 02:52 PM. |
02-24-2021, 12:41 PM | #30 | |
I wish I could have found my build sheet. Nothing was under the seat or carpet. I did find an interior bolt in mint condition under the carpet that the installer dropped and left. Maybe there is a build sheet behind the dash or behind the door panel. I have yet to check those locations. My gas tank is external. Nothing was on top of it but I'm glad I checked as the original fuel line was cracked. |
02-24-2021, 01:14 PM | #31 |
Thank you; I did answer all the questions you posted on my "Intro" thread, too.
K
02-24-2021, 01:39 PM | #32 | |
02-24-2021, 02:43 PM | #33 | ||
There were usually around 7 different assembly plants building squarebodies for any given model year. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-24-2021 at 03:10 PM. |
02-24-2021, 02:49 PM | #34 |
Build Sheet:
02-24-2021, 02:49 PM | #35 |
SPID Label:
02-24-2021, 10:25 PM | #36 |
My old '98 Corvette had the build sheet in the frame rail. Only way to get it was to remove the nose.
03-07-2021, 03:45 PM | #37 |
On the build sheet what does the routing number indicate? This is found on the bottom of this build sheet in box 120 with the value of VW.
