Old 03-21-2021, 08:33 PM   #1
Bbarbeau
Going back to factory intake and carb
My '72 with a 350 has had the intake and carb changed to an Edelbrock. I'm thinking about changing it back, not that it doesn't work right, I'm just want it to be closer to factory.
Is there anything I need to look out for when looking for parts? Are intakes the same for car and truck applications etc?
Thanks!
Bbarbeau is offline   Reply With Quote
Old 03-22-2021, 10:42 AM   #2
MAC71Cheyenne
Re: Going back to factory intake and carb
Can't answer that but interested is hearing from those that can....
MAC71Cheyenne is offline   Reply With Quote
Old 03-22-2021, 11:14 AM   #3
MARKDTN
Yes, stock Q-jet intakes should be easy to find. Really should fit '69-85 305 and 350 truck, van, Camaro, Impala, Nova, Corvette (to '81), Chevelle..... Some of those would be factory aluminum, especially later ones. Some might have more coolant holes that you need, but any would work before the center holes to the head changed angle about 1986. '66-68 would also fit but have a oil fill hole in the front that would need plugged.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-22-2021, 11:19 AM   #4
StingRay
StingRay's Avatar
Just watch out for some of the older stock 4 BBL intakes that need a metal shim under the carb as the exhaust heat passages can come up through the top of the intake and the shim blocks the exhaust from entering back into the intake. Great carb heat for clod climates but a little too great for any kind of performance. I found one of these as a kid and was a bit puzzled by it but with all the right parts it worked fine. Id stay away from the later intakes with EGR and set up for divorced choke unless you are planning on using a a later divorced choke Q-Jet. I'd just paint the intake a swap the carb. The later divorced electric choke Q-Jets are an excellent carb.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-22-2021, 01:56 PM   #5
Bbarbeau
Thanks everyone, that's really helpful! I'm assuming that stuff like this is plentiful but now I can look for the right things.
Divorced choke: what year did they start doing those?
Old 03-22-2021, 03:06 PM   #6
54blackhornet
54blackhornet's Avatar
I removed the original cast iron intake on my 71 GMC. Installed an aluminum Edelbrock Performer with the provision for the divorced choke. Original QJet on top. This setup I believe is superior to stock. I have the original intake hanging on the shop wall.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-22-2021, 03:17 PM   #7
Bbarbeau
Oh interesting! Were you having trouble with the factory set up or looking for better performance? Just curious.
Old 03-22-2021, 03:45 PM   #8
BROWN 70
BROWN 70's Avatar
x 2 post 6. lighter and more port velocity. good luck, BROWN 70
BROWN 70 is offline   Reply With Quote
Old 03-22-2021, 05:37 PM   #9
palallin
I went the other way and replaced a stock intake with an aluminum one and a Q-Jet with an Edelbrock. I, too, am now thinking of going back. The weight difference is absolutely trivial in anything except a full-on race application. I got better mileage with the Q-Jet. Only two things are keeping em from acting on my plan:
1) I need to collect the parts, and I'd want to have the carb seen to by someone who knows his business
2) In a K truck, the distributor is so wretchedly close to the firewall that pulling it is no fun.
One of these days, however, I will get up the gumption and tackle the job. It will give me a change to clean things up and seal a few leaks, too.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-22-2021, 06:15 PM   #10
MikeB
MikeB's Avatar
This thread brings back memories. When I got my 69 C10 in 1989 it had a stock 307. I bought a used Q-jet manifold for $10 that turned out to be from a 69 350. Then bolted on an NOS Holley Economaster 450 CFM Q-Jet replacement. Found it in a dusty, beat-up box in the back of a parts store. Those guys just about gave it away! Along with dual exhaust, that 307 felt like it had gained 50 horsepower. And fuel mileage actually increased by 20%.
BTW, Holley still sells Q-jet replacements, but they are totally different than the Economaster.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-22-2021, 07:43 PM   #11
Bbarbeau
Your comment about the distributor got me thinking that the distributor has been changed to electronic ignition (I think it’s HEI). Is that a problem with fitting around stock parts?
Old 03-22-2021, 08:29 PM   #12
RustyBucket
RustyBucket's Avatar
There are inexpensive small cap HEI distributors. They come in black and look stock with an external coil.
https://www.speedwaymotors.com/Chevy...xoC5YYQAvD_BwE
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 03-23-2021, 09:52 AM   #13
palallin
Not really. The problem is just that it practically touches the firewall. You just learn a whole new vocabulary
Old 03-23-2021, 12:18 PM   #14
MikeB
MikeB's Avatar
Not a problem on my 69 C10 with the engine mounted in the forward position. There's 3"-4" between large cap HEI and firewall.
Mike
Old 03-23-2021, 01:57 PM   #15
bry593
You'll want a 1969-1974 iron intake (should be a date cast in). These have the mounting pad for the divorced choke coil that is used on Quadrajet 70 series carbs from 1969-1974. You definitely don't want to use a 170 series carb (1975-late 80's) on an early intake and vice versa, else your choke will not work.
I do not recommend the hot air intake from 1975-1980ish. That choke style is terrible. You can convert an early 170 series carb to the later electric choke ($45), but you need to plug up the hot air passage on the intake manifold.
So, focus on finding a 1969-1974 manifold and Quadrajet. These work really well unless you buy a Quadrajet from a rebuilder. Rebuilders do all sorts of stupid things and it's a gamble. Best to buy an untouched original at a swap meet and rebuild it yourself.
When looking for a good Quad rebuilder, the main thing is to look for a downward bend at the front of the carb mounting holes. A lot of people went full shade monkey and hammer torqued the screws. This squishes the airhorn and the zinc carb body. Basically smashes it into a frowny face shape. Avoid these as they are pretty much junk.
Another common Quad issue is corrosion in the bowl/main body. Gasohol will screw up everything once it begins to decompose.
As a manifold alternative, you can pick up an old school Weiand or Edelbrock spread bore aluminum manifold. Just be sure it includes the little piece that the choke coil mounts to. Be sure to check for stripped threads and corroded water neck mount. If you paint the aluminum orange, most won't notice it isn't original.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 03-23-2021, 04:57 PM   #16
54blackhornet
A properly set up QJet is far superior to a Edelbrock as far as mileage goes. Ask me how I know...
71 C-20
07 Magnum RT AWD
Old 03-23-2021, 04:59 PM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Cant beat the Edelbrock 2101 with a properly tuned Quadrajet...The 2101 does have the divorced choke option on it.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-23-2021, 05:04 PM   #18
Ironangel
Ironangel's Avatar
I fully agree with this! The QJet is far more mileage friendly than either the Holley or Edelbrock carbs...
"Two Seventy Two's"
02 3/4 ton Express
Old 03-23-2021, 05:34 PM   #19
MikeB
MikeB's Avatar
Can't beat those tiny primaries for fuel mileage and throttle response. I don't know why we didn't see more aftermarket carbs like that.
Mike
Old 03-23-2021, 09:45 PM   #20
dmjlambert
dmjlambert's Avatar
If you want closer to stock but don't mind a newer Quadrajet, I am enjoying my later model Quadrajet with electric choke from National Carburetors. It is model number ND4478 for 1981-86 trucks. They make remanufactured ones (that I have) and they now have new ones. I am using it on my original 1969 hot slot manifold. That is the type that StingRay mentioned above and I use the special composite and metal gaskets with it, and the heat passages have been plugged on mine. So if you end up with one of those it is workable.
http://67-72chevytrucks.com/vboard/showthread.php?t=762751
http://67-72chevytrucks.com/vboard/showthread.php?t=765690
Old 03-23-2021, 10:47 PM   #21
StingRay
StingRay's Avatar
Yup that one. Seems like yesterday but it was 40 years ago. Smoking price they have on Q-Jets.
Canada
Old 03-24-2021, 09:12 PM   #22
Bbarbeau
Wow, thanks for the responses! Lots of detail there that is so helpful. I do wonder if getting to some swap meets would be the easiest/cheapest way to get parts likely.
So National Carb - that’s a really good price. I saw that Rock Auto had some too but I don’t know where they were coming from.
Old 03-25-2021, 09:55 AM   #23
MikeB
MikeB's Avatar
I wonder how many mass market rebuilders install throttle shaft bushings and address float bowl leaks. I'd get in touch with Cliff Ruggles, a guy who literally wrote the book on Q-Jets to see what he has available.
https://cliffshighperformance.com/
Mike
Old 03-26-2021, 10:07 PM   #24
Bbarbeau
Oh cool, thank you! That’s awesome, I had no idea, that looks like a must have book too.
Old 03-27-2021, 02:37 AM   #25
toolboxchev
Thanks!
have been watching this for about a week now. machinist tells me those factory intake actually have a curve in the machined surface that mates to the heads.
I looked at my factory intake upon my last top end rebuild 10 years ago. Whatta ya know????
I still have the factory carb from 1970 in near perfect condition to rebuild. I am looking at an 84-86 carb from Cliff if you know what I am after.
PM me for more details.
toolboxchev is offline   Reply With Quote
