03-30-2021, 10:26 AM | #1 |
Time for a freshen up on the 68 C20!
Well, it’s been awhile since I last posted. Still have been reading and learning on the site. What knowledge is available on here is incredible! I took a early retirement from my job of 33 years and my wife says to get the truck running better for your retirement present. HELL YEAH!!! So the 327 got dropped off at the engine shop for a rebuild and I ordered a new filter and shift kit for the turbo 400. Decided to have the original 327 rebuilt because the LS swap is just not for me. (Not dissing it at all!) Motor dude says I should have around 350 hp which is good for me. Biggest decision so far is headers or 2 1/2” ram horns? Any thoughts are welcome. Also, going to possibly swap out the HO52 4:10 rear end sometime soon as well. Just thought I would share with my fellow enthusiasts!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
03-30-2021, 10:44 AM | #2 |
Re: Time for a freshen up on the 68 C20!
Beautiful truck....
I vote ram horns because a) you aren't wanting a hot rod (I think) and b) every set of headers I've ever had either leaked or had to be dented to fit properly. |
03-30-2021, 10:52 AM | #3 |
Awesome deal on the retirement and freshening up the truck. I will never put a set of headers on a vehicle again...I'm too old, they are too loud, and for about 1 HP per cubic inch (in that ballpark) a set of cast manifolds can work just fine. When approaching the 1HP/CI, I have always port matched the exhaust manifolds to a "more open" set of gaskets (along with the heads) to maximize their throughput. This can be done on the intake side too, but If I had to choose to just do one...I'd do the exhaust side when using manifolds over headers.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
04-02-2021, 07:59 AM | #4 |
Thanks guys! I’m 99% sure on the ram horns! 👍
04-02-2021, 08:13 AM | #5 |
Ramhorns all the way! I love the look of that truck.
Congrats on retirement. My first day of retirement is next Monday.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
04-02-2021, 08:39 AM | #6 |
It says "Speed Shop" on the doors, so headers! J/K, rams horn manifolds work too, I guess, maybe.
BTW, my Summit stainless full-length headers went on with no fitment issues and no leaks. Beautiful truck.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
04-02-2021, 08:50 AM | #7 |
Thanks! Do you have a part number for the headers by chance? Maybe I’ll check them out.
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) Last edited by Stranny64; 04-02-2021 at 09:03 AM. |
04-02-2021, 10:46 AM | #8 |
The Older Generation
I have basically the same truck as yours, '68, 327, TH400 with the 4.10 rear end. I am just finishing up the new brakes on the Dana 60 3.54 rear end to install in mine. I think it will make it a lot more fun to drive. Luckily my engine is in really good shape so I don't have to do anything to it. Another vote for the stock manifolds from me but I'm an old fuddy-duddy so that figures... Good luck with your retirement and your rebuild. LockDoc
04-02-2021, 11:13 AM | #9 |
LockDoc,
Is the rear ended swap a direct fit? I was trying to find out what years, if any, are a direct simple swap. Still leaning towards some Corvette style 2 1/2” center ram horns. Thanks a bunch!
04-02-2021, 06:00 PM | #10 | |
https://www.summitracing.com/parts/sum-g9006-ss
04-03-2021, 12:07 AM | #11 | |
Yes, with the Dana rear end I have it is a direct bolt in, but the Dana 60 3.54 coil spring rear ends are kind of hard to find. Used in big block trucks only. LockDoc
