Old 04-07-2021, 04:11 PM   #1
pwdcougar
pwdcougar's Avatar
70 emergency brake and wiring in a 68 firewall
My donor truck is a 68 and I'm looking to swap in the wiring and ebrake from my 70. Anyone done this? I can see that the firewalls are different from my tear down pics. The green/blue is the 70 and the saddle is the 68
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 04-07-2021, 04:48 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: 70 emergency brake and wiring in a 68 firewall
Interestingly enough the problem is actually with the location of the 68's fusebox, you will need another hole for that cause it needs to move over.
I would make a template of the firewall for the 70 but start with that particular mod before worrying about the brake placement.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-07-2021, 05:37 PM   #3
BigBird05
Instead of a template I would cut out the firewall from the 70 and weld it into the 68.
BigBird05 is offline   Reply With Quote
Old 04-07-2021, 06:27 PM   #4
pwdcougar
pwdcougar's Avatar
Unfortunately the 70 firewall is long gone! I'll have to find a source for a template
Old 04-07-2021, 06:33 PM   #5
dagnabbitt
dagnabbitt's Avatar
If it were me I’d remove fuse box, install e brake, then eyeball the new location for fuse box. Then weld up old fuse box hole.
If you want it to be perfect, as has been suggested a later firewall would be handy, you might be able to find a garbage cab at the junkyard to cut it out of.
Good news is it is quite doable, the e brake itself should need no modification.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-07-2021, 06:41 PM   #6
pwdcougar
pwdcougar's Avatar
I didn't take great pictures of how the ebrake goes in though. Between the two pics I'll take your advise and eyeball the fuse block location.
Old 04-07-2021, 06:54 PM   #7
dagnabbitt
dagnabbitt's Avatar
Wes at classicheartbeats (?) did it to a suburban but that part of his build doesn’t seem to be available online anymore, maybe he can help. Good luck!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-07-2021, 09:17 PM   #8
BigBird05
Why do you want to run the 70 harness? Is it because of the P.B. taking up the space were the 68 fuse block is now?
Old 04-07-2021, 11:33 PM   #9
lugnut
lugnut's Avatar
I put a 72 brake assembly in my 67. I just rotated the fuse block 90 degrees so it sits the long way up and down. It's a tight fit next to the brake assembly but it fit. Just drilled two new holes for the fuse block once it was rotated. I had to drill holes for brake assembly and install that first.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 04-08-2021, 11:19 AM   #10
pwdcougar
pwdcougar's Avatar
Great information thanks. Is the installation of the 72 e brake pretty much intuitive?
Paul
Old 04-08-2021, 11:53 AM   #11
lugnut
lugnut's Avatar
Paul
For the most part it is but I did some other things along the way that made it easier. I was replacing the full dash anyway f to install AC so I used one from a 72. That one has the hole on the bottom just above where the new foot pedal brake handle will be. Then I just made a template of cardboard from the 72 firewall to make sure my two bolt holes lined up for the assembly. A bit of trial and error but it is solid and functions great. I also got a new cable for a 72 while I was at it.
Old 04-08-2021, 02:54 PM   #12
pwdcougar
pwdcougar's Avatar
My 70 harness is in much better condition compared to the one from the 68. The main reason for the ebrake swap is the 68's was mia.
Old 04-08-2021, 04:04 PM   #13
Accelo
Accelo's Avatar
A picture of a 72, possibly it will help?
Accelo is offline   Reply With Quote
Old 04-09-2021, 05:05 PM   #14
pwdcougar
pwdcougar's Avatar
Thanks!
Can someone take a pic of the placement of the ebrake assembly under the dash?
Old 04-09-2021, 06:58 PM   #15
lugnut
lugnut's Avatar
Thanks!
Here is my 67 converted with the fuse block rotated.
Old 04-10-2021, 12:29 AM   #16
pwdcougar
pwdcougar's Avatar
Thanks! The pictures will be a big help!
