Old 06-28-2021, 06:43 PM   #176
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Got the dash all finished up went with semi gloss black stripes with the gray looks great.
Also got the front and rear glass in and doors all put together. All the seals from Steele rubber are amazing over the LMC stuff. the peel and stick door seals work great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-28-2021, 07:53 PM   #177
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
And BOOM it is done!!
I had a safety this morning then went and got it plated. Went for a few test runs and stopped to fill it up then drove it to work. I have 30mi on it now all is good but it is making no boost. So overall success, front bumper sits at 7".
1951 MG TD
Old 06-28-2021, 11:21 PM   #178
oldman3
oldman3's Avatar
Re: 1950? S-10 tdi
Alright, nice to see it on the road...Jim
oldman3 is offline   Reply With Quote
Old 06-29-2021, 07:34 AM   #179
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1950? S-10 tdi
Looks great!.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-29-2021, 08:53 AM   #180
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
hell yeah!
but please make the PSIs work ... how much are you hoping to run? the tune in my golf was basically 18psi across the board.
6DoF is online now   Reply With Quote
Old 06-29-2021, 09:07 AM   #181
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
Congrats, looks great.
Tempest67 is offline   Reply With Quote
Old 06-29-2021, 07:55 PM   #182
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Yes it is!
Originally Posted by 61_FL_Apache View Post
Looks great!.
Originally Posted by 6DoF View Post
hell yeah!
working on it.
Thank you
1951 MG TD
Old 06-29-2021, 09:41 PM   #183
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
did you have any trouble with a safety with wheel spacers?
Old 06-30-2021, 03:40 PM   #184
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
No the mechanic just said he is not a fan of them. If you are worried get a safety without them then go home and put them on.
1951 MG TD
Old 06-30-2021, 03:45 PM   #185
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
I had mine done by a 'friend', but I was not sure if it was legal to have them or not. (my rears will hit the box without them, 1 1/4 in)
Thanks, and have a good trip this weekend.........going in style
Old 07-01-2021, 10:31 AM   #186
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
i've never seen a wheel "adapter" be illegal, and i've seen them run off-road races just fine. an adapter being a large pc that bolts to the hub, and a wheel bolts to the pc. a spacer is just an elaborate washer that moves the wheel out on the hub studs, and those are definitely illegal over like 1/8" or something.
Old 07-01-2021, 03:04 PM   #187
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Thanks ya not illegal.
Yes the stud spacers are bad news all around.
1951 MG TD
Old 07-01-2021, 03:06 PM   #188
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
121mi in 4 days, so far no issues really, other than my front marker light unplugged itself.
Put upgraded injectors in yesterday (needed to for the tune) now getting 7psi should be around 18psi but I get the boost quicker so it is getting faster lol. It is a fuel quantity problem should be seeing a bit more smoke, so I'm working on figuring that out. I'm still driving it up for camping because there are really no issues driving it.
1951 MG TD
Old 07-01-2021, 03:17 PM   #189
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
i ended up "adjusting the pump" ... by hitting it with a hammer. seriously though, i forget the metric, but with the engine running and the VGT cable plugged in as i watched a specific value. my issue was it idled like crap. loosened the bolts on the top of the pump, not so much it leaks, smacked it with a hammer a few times til the value landed in range, and instantly the idle was perfect. tightened the bolts and game on, weirdest thing ever.
Old 07-01-2021, 03:17 PM   #190
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
i also had vacuum leaks that would keep the turbo from fully kicking in, check for leaks.
Old 07-01-2021, 05:58 PM   #191
rusty76
rusty76's Avatar
Re: 1950? S-10 tdi
Truck is really turning out nice!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-04-2021, 08:26 AM   #192
burnin oil
Re: 1950? S-10 tdi
Glad the good old hammer mod worked for you. I had several injection pumps on the jetta since you can't buy the internal timing ring that's electronic. The worst offender so far was a junkyard scored brand new bosch factory reman. I had to hammer it over until it idled like an old diesel truck to get any off idle power. It shakes a little but now runs good. Makes me miss the 11mm pump.
Check the turbo arm. It's the waste gate looking thing. It actually controls the variable turbo and how the vanes are set. In other words they control how the initial boost begins to come on. Also a leak in the intake tract after the MAF will seriously defuel the motor. Hammering the pump can mask problems here since you are adding more fuel to the mix even though the computer thinks it's in stock trim. As far as I understand the programming, the computer has no idea what the actual fueling is and only blindly adds or subtracts it based on what it thinks it is receiving.
burnin oil is offline   Reply With Quote
Old 07-05-2021, 09:31 AM   #193
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Yes I did the hammer adjust on Thursday made it a bit better up to 8psi now lol
The only thing vacuum does for me is brakes and wipers
Thank you. It's nice to drive.
This one is controlled manually with a psi wastegate, I confirmed and I have it wired shut for now. I have the vacuum controlled variable vane on my Jeep TDI and played with it enough to learn how it works. thanks for the info.
1951 MG TD
Old 07-05-2021, 09:48 AM   #194
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Other than down on power still the drive up north 2hrs was a success. I have 360mi on the build so far and all is good, like nothing has gone wrong. The weather has been hot around 80-100* with humidity and the truck is running 160-170* the trans is 150-170*. I got 30mpg on this last trip of 230mi. I have a few new rattles and need to adjust my fuel gauge.
1951 MG TD
Old 07-05-2021, 10:50 AM   #195
Rickysnickers
Re: 1950? S-10 tdi
Job well done!!!
Old 07-05-2021, 11:08 AM   #196
Tempest67
Tempest67's Avatar
Re: 1950? S-10 tdi
Glad to hear you had a successful trip.
I love the 'action' photo from behind the wheel.
Truck looks great, congratulations.
Old 07-06-2021, 10:10 AM   #197
6DoF
6DoF's Avatar
Re: 1950? S-10 tdi
i freakin love it man!
Old 07-06-2021, 12:38 PM   #198
jae
Re: 1950? S-10 tdi
Outstanding! The truck really looks great.
jae is offline   Reply With Quote
Old 07-08-2021, 08:02 AM   #199
lower50's
lower50's's Avatar
Re: 1950? S-10 tdi
Originally Posted by Rickysnickers View Post
Job well done!!!
Thanks ya I have that shot as my background on my computer.
Thank you
Thank you much.
1951 MG TD
Old 07-08-2021, 08:40 AM   #200
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1950? S-10 tdi
The truck looks great, even the flat bed. Hopefully you can get the low boost gremlin figured out but keep driving the snot out of it!
Ryan
1969 Chevy milk truck
chevy, custom, diesel, gmc, s10
