07-16-2021, 11:23 AM | #1 |
1957 10100 Task Master - Info needed
Hey everyone,
I have a 1957 Task Master with a 322 and the double drive shaft tandem axles, I would like to get a little more info and was hoping that you could help? https://photos.app.goo.gl/vty7oWw5tS7amYSy7 Mike |
07-16-2021, 12:38 PM | #2 |
Re: 1957 10100 Task Master - Info needed
Not sure what information you're after but this info packet has a lot of great data in it to get familiar with the 1957 trucks.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
07-16-2021, 01:30 PM | #3 |
My mind went into imagine mode when I saw your truck. Crazy potential!!!
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
07-16-2021, 04:18 PM | #4 |
Thank you, I will take a look. I was also looking at seeing if there are other trucks out there I could use for reference. I have never seen one like this and wanted to see how many others have been around one or have one.
Mike |
07-18-2021, 11:40 PM | #5 |
Hy mbuchli, there is another similar tandem owned by an A.T.H.S. member, it has a 322 Buick engine as well and it also has the Powermatic automatic transmission. A rare truck to be sure, I have a 1957 Chevrolet 8700 tandem, but it only has a 283 in it. Good luck with yours.
07-19-2021, 09:06 AM | #6 | |
07-19-2021, 09:45 AM | #7 |
Hy mbuchli, are you sure your tandem has a brownie, or are you thinking of the power divider? One input from the transmission, two outputs to the two differentials.
07-19-2021, 10:03 AM | #8 |
it could be the power divider vs. brownie. I didn't inspect it closely when we pulled it from where it has been resting for almost 40 years.
