Old 07-22-2020, 10:17 AM   #1
mister.freeze
mister.freeze's Avatar
'72 Mirror won't stick
So, for the last 2 years, I haven't been able to keep my mirror glued to the windshield very long. The previous 20 years, I think I had to glue it on maybe twice. I've used several of the different glue kits like Permatex, but those lasted 2 months at best. It was a hassle, so I just kept some super glue in the truck which did no better. Ran out of that and tried Gorilla glue. about the same.
Yes, I clean the button AND the glass before hand. Yes, I use tape to hold it in place. I've done it at night and in the middle of the day. It will fall off during the day while at work, while driving, and even overnight. What gives?
It's like that part of the windshield has just quit letting anything stick to it for very long. Thoughts?
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 07-22-2020, 11:22 AM   #2
simicrintz
Re: '72 Mirror won't stick
I've cut the Gorilla double sided tape to fit the outline of what I am sticking and have had great results with it.
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 07-22-2020, 02:30 PM   #3
truckster
truckster's Avatar
The adhesive glass shops have is more durable. They'll often glue them on for free (I always did).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-23-2020, 10:28 AM   #4
Tmend
Tmend's Avatar
have this on my 72 blazer. no glue needed
ELUTO Rear View Mirror Anti-glare Mirror Universal Interior RearView Mirror with Suction Cup for Car Truck SUV 9.5’’(240mm)
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 07-24-2020, 02:08 AM   #5
Richard
Have used the part stores glue with good results. Only suggestions I would have are to clean glass with #0000 steel wool then isopropyl alcohol. Wait at least 24 hours before mounting mirror to button. Have never had good luck with the plastic buttons. Hope yours is metal.
Richard
Old 07-27-2020, 04:36 PM   #6
hemi43
hemi43's Avatar
Can you use a 70' mirror? Mine gets mounted on the windshield header, not the windshield.
If not, you can etch the glass for better adhesion. You can get the acid etch from any place that sells stained glass supplies. I've used it in the past and works great.
hemi43 is offline   Reply With Quote
Old 07-27-2020, 06:54 PM   #7
Gerty68
Rough up the surface of the mirror button. Clean both surfaces very well. Use the activator on both glass and mirror button. Make a 8 with the glue on bracket and hold it in place for 30 seconds.You should feel it solidify on glass(keep it straight). Wait 24hrs to hang mirror. If that doesn’t work take it to a glass shop. Usually free-maybe slip em a $5. Good luck!
Gerty68 is offline   Reply With Quote
Old 07-27-2020, 07:02 PM   #8
Gerty68
Old 07-28-2020, 01:35 AM   #9
Tmend
Tmend's Avatar
Old 07-28-2020, 10:41 AM   #10
mister.freeze
I like the idea of etching the glass.
the suction cup looks viable too. How was that done?
I've thought about a '70 mirror, but kinda like that little space freed up for magnetic stuff.
Old 08-27-2021, 03:33 PM   #11
mister.freeze
So since then, the mirror has come off probably 3 or 4 time. Fell off again yesterday. So today, I cleaned the window with Windex, then Alcohol. Button too, after sanding it to be sure all previous glue was off (metal button, BTW). The auto part store had some Permatex stuff for $11, and this for $7, but this says EXTREME STRENGTH. We’ll see.
Old 08-27-2021, 06:50 PM   #12
Thealien
Thealien's Avatar
I tried 3 brands, a couple twice. Went to the local glass shop. Not free though. But worth it to have a rear view I am not afraid to adjust.
Old 10-21-2021, 03:50 PM   #13
El Dorado Jim
Originally Posted by A1971Blazer View Post
I went thru it a few times then I just bought one that attaches to the windshield frame like the 71 and earlier....problem solved..
I'm not anal about every "detail" being "original"....just tired of the mirror falling off
on my 72 pickup i did the same thing, used a mirror and bracket from an older truck, i hated that the mirror falls off
El Dorado Jim is offline   Reply With Quote
Old 10-21-2021, 10:51 PM   #14
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE this says EXTREME STRENGTH. We’ll see.[/QUOTE]
Well... if it's Extreme. Lol
Tom Vogel is offline   Reply With Quote
Old 10-21-2021, 11:19 PM   #15
Warrens69GMC
Warrens69GMC's Avatar
Don't clean with Windex, clean with thinner......
Old 10-29-2021, 12:06 PM   #16
mister.freeze
so far, so good. I really think weather has something to do with it. As things cool, I expect it to fall off again soon...
Old 11-18-2022, 01:31 PM   #17
mister.freeze
So that was just over a year; fell off yesterday. I put it back up with Krazy brand glue I had around the house. The button had all the glue on it; nothing stayed on the glass.
Old 11-18-2022, 01:34 PM   #18
SeventyOne
go 69-71 style mirror and be done with it
SeventyOne is offline   Reply With Quote
Old 11-18-2022, 01:37 PM   #19
A1971Blazer
A1971Blazer's Avatar
After mine fell off the third time....that's exactly what I did....
Several people stated "that's not correct for a 72"
to which I replied "you've obviously mistaken me for someone who give a sh!t"...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-18-2022, 04:12 PM   #20
SeventyOne
exactly. may not be correct but it's better in every way
Old 11-21-2022, 09:11 AM   #21
jaros44sr
jaros44sr's Avatar
16690360897585795959267109694811 by [url=https://www.flickr.com/photos/97391199@N06/]
Mine hasn't fallen off since I bolted it on, plus it has the green cover to match my interior
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-22-2022, 03:35 PM   #22
Sandtrap9072
Sandtrap9072's Avatar
Hit the mirror tab with some sand paper, then try it again. When i worked at a glass shop we used the loctite brand. it was great!
Sandtrap9072 is offline   Reply With Quote
Old 12-02-2022, 01:27 PM   #23
mister.freeze
Well, the Krazy Glue didn't last long, a few days. I tried some double-sided tape I had laying around: it was good waterproof stuff. The adhesive worked but the foamy black substrate did not. I got some JB Weld Mirror Weld, trying that. Also picked up a different button; it's plastic but has a much bigger contact area for the glass. will try that next.
Old 07-16-2023, 07:33 PM   #24
mister.freeze
Fell off today, it’s been 7-1/2 months. Trying that plastic button kit now.
Old 07-17-2023, 09:02 AM   #25
hemi43
hemi43's Avatar
Like I mentioned 2 years ago. Etch the glass and be done with it.
