#301 |
Re: My 56 build
Lots of nice fab. work. Looking great. Keep up the good work. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#302 |
Re: My 56 build
Thanks guys. Slowly putting pieces together. Working on mounting the shifter today.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#303 |
Re: My 56 build
Here’s the start to the shifter and a mock up of the center console. I just have to make a bracket to hold the cable on the transmission. Hopefully I won’t need to adjust/grind new detents to match up with the newer trans. Time will tell
#304 |
Re: My 56 build
Shifter appears to be fine. All the shifter detents Line up with the transmission. So hopefully that will work out.
Also ordered a driveshaft. The one I had was too short. Go figure, going from a 4 speed to an 8 the driveshaft needs to be longer. So more research and I found a bill of material list for gm driveshafts. It includes everything from length, u joint size, shaft material, Oem part number, etc. I found one the right length with the correct u joints, plugged the oem number in rockauto and ordered it. $300 direct from rock auto! Here’s a link to that bill of materials page. https://www.demandaam.com/technical-...l-of-materials I ordered a new pinion yoke to match the 1410 u joint and I should be able to drive this thing out of the garage. I made an appointment to see if it can be aligned for August 27. Mock up is nearly complete ![]()
#305 |
Re: My 56 build
Nice build and good work with the Gen V swap. I am looking at your driveshaft info and that might save a whole lot of trouble. Thanks
Kermitt's 47 truck build |
#306 |
Re: My 56 build
No problem, hope it helps
#307 |
Re: My 56 build
Jason 56, are you using the Camaro SS fan with PWM control or did you find something else that fits the bill? If it is the Camaro fan, how deep is it from the rad to the back of the motor? I am looking for a compact solution that will move some air. Nice job hiding all the engine controls.
#308 | |
Re: My 56 build
#309 |
Re: My 56 build
Pinion yoke arrived. Last piece of the puzzle needed to pull it out of the garage. Along with a couple trips to my local parts store for fluids etc.
#310 |
![]() Join Date: Mar 2011
Re: My 56 build
Congrats, that first drive, no matter how far, will always remain with you...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#311 |
![]() Join Date: Apr 2016
Re: My 56 build
Great feeling when you can drive it out of the garage. She looks great.
#312 |
Re: My 56 build
Congrats. Looks awesome and the stance is bang on, in my opinion. Do you have a color picked out yet or does that change daily?
#313 |
Re: My 56 build
Congrats! That is a Big deal to go from a pile of parts and ideas to a running, driving machine. Everything else is icing on the cake.
#314 |
Re: My 56 build
NICE! that's a huge moment!
#315 |
Re: My 56 build
Thanks everyone. I’m hoping it doesn’t rain tomorrow. I’m putting it on the trailer to bring it to be aligned. We’ll see. It’s forecasted to rain all day.
#316 |
Re: My 56 build
I agree with the stance. I kept trying to level the rake and found these trucks just look better raked! As for color I’ve settled on a new infinity color. It’s called hermosa blue. It’s a midnight blue pearl. Should look really sharp.
#317 |
Re: My 56 build
Trailered the truck back from the alignment shop today. Everything came out great
#318 |
Re: My 56 build
Installed a one piece power window kit. I need to obtain the seals to confirm the shape of my templet. Otherwise the install was easy. Hopefully they seal nicely.
#319 |
Re: My 56 build
Received my exhaust kit today. This is the next project.
#320 |
Re: My 56 build
Man, it’s really coming along
What one piece window kit did you use? Is it power window? |
#321 | |
Re: My 56 build
https://www.classicparts.com/1955-59...tinfo/18-766B/
#322 |
Re: My 56 build
Here’s a start to the crossover. I’m still waiting for my mufflers to see where everything falls.
#323 |
Re: My 56 build
Spent most of the day today knocking out the exhaust. Mufflers were delivered around noon and hours later… an exhaust. The kit I used was 2.5” mild steel and a pair of borla mufflers. It sounds good
#324 |
Re: My 56 build
A few more pictures. I decided to have the exhaust exit the rear fender. I plan on cutting the exhaust flush with the fender and the paper ring will be chrome… maybe.
#325 |
![]() ![]() Join Date: Oct 2014
Re: My 56 build
Looks great, and the pictures are turned the right way!! Thank you for posting!!!
