09-27-2021, 04:23 PM | #1 |
GMC Headlight Bezels and 3/4 Ton Control Arm Shaft and Leaf Spring Bushings
Buyer pays all shipping and fees
C20 Lower Control Arm Shaft - Moog K6147 - I ended up thinking I lost one of the caps and in the middle of a project I ordered a second one. Then when I moved to a new house, I found it. One cap is painted, was test fitted, then "lost." Never torqued, installed, or used. $15+shipping thread closed C20 Leaf Spring Bushings - Moog SB319 - I learned (the hard way) that the bolt size changed some time between 1968 and 1971. These bushings were pressed in, but never used. I ended up pressing them out because the bolts I was using were bigger than these bushings. This is a full set for a Dana 60 rear end and I put anti-seize on them before pressing them in. $30+shipping SOLD GMC Headlight Bezels - I should call this the "lessons learned" sale thread. I bought these later style headlight bezels not knowing they wouldn't fit into the 1967/8 grille. Minimal rust, super clean, no issues except for two small dings. $50+shipping thread closed Items consolidated into another thread. This thread is closed.
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-10-2021 at 02:49 PM. |
09-27-2021, 04:25 PM | #2 |
Re: 3/4 Ton Control Arm Shaft and Leaf Spring Bushings and GMC Headlight Bezels
Lower control arm shaft - Moog K6147
1968 GMC C2500 Long Bed Fleetside |
09-27-2021, 04:26 PM | #3 |
Moog SB319 Leaf Spring Bushings - I put anti-seize on them before I pressed them in
09-27-2021, 04:30 PM | #4 |
pics of the bezels
1967custom |
09-27-2021, 05:01 PM | #5 |
GMC Bezels
09-27-2021, 05:02 PM | #6 |
GMC Bezels 2
one small ding on each bezel as shown
09-28-2021, 09:24 AM | #7 |
bump
10-05-2021, 01:54 PM | #8 |
bump - prices lowered and open to reasonable offers
10-14-2021, 01:34 PM | #9 |
Prices dropped - help me clean out my garage!
11-04-2021, 05:09 PM | #10 |
11-04-2021, 09:24 PM | #11 |
The Older Generation
What size is the bolt hole in the bushings. Thanks, LockDoc
11-05-2021, 04:56 PM | #12 |
Here are pics of the OD and ID. Looks like the ID is for a 9/16” bolt.
11-06-2021, 07:55 PM | #13 |
Thanks. See what the shipping would be to Montezuma, IA 50171. LockDoc
11-07-2021, 09:31 AM | #14 |
I’ll work on that today/tomorrow. I also have a set of OEM door locks (no keys) I pulled off a junkyard truck. I was gonna sell them, but if you want them I’ll throw them in the box. You’ve helped me out so many times!
11-07-2021, 09:51 AM | #15 |
I’ll dig around. I might actually have two sets…
11-07-2021, 09:53 AM | #16 | |
Sounds good. No hurry on my end. LockDoc
11-09-2021, 03:29 PM | #17 |
The cheapest shipping option looks to be a small flat rate box through USPS at $9.20.
11-10-2021, 11:41 AM | #18 | |
Sounds good. PM me your PP info. Thanks, LockDoc
