Old 12-06-2021, 08:13 AM   #51
biketopia
Re: LS turbo advice needed...
It takes up one of your already limited input's with the term x, only real advantage would be for data logging to see if you have a fuel supply issue under load.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-06-2021, 07:50 PM   #52
akdg87
akdg87's Avatar
the fuel pressure doesn't take up any inputs, it is nice to have for fuel pressure monitoring, you can also setup a safety with it. I don't think the term x uses the fuel pressure for any fueling calculations. A $10-50 sensor and some table scaling you could have actual pressure displayed is pretty easy.
Are you running a boost reference 1:1 fuel pressure regulator?
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 12-06-2021, 09:38 PM   #53
OKGMC4
OKGMC4's Avatar
Mine has the factory 2001 truck intake with the vacuum regulator and return line.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 12-07-2021, 02:18 PM   #54
akdg87
akdg87's Avatar
it would probably be helpful to have the fuel pressure reading just to keep an eye on it. i believe there's an adapter fitting on the market for the fuel pressure schrader valve to 1/8" npt thread.
build thread
2009 CTSV Sedan
Old 12-08-2021, 07:22 AM   #55
biketopia
My bad, I've been looking at so much different holley stuff lately I don't know why I forgot the term x has the provisions for it built into the harness. So with that being said like akdg87 said, pick up a sensor, I recommend looking into low dollar motorsports for a sensor vs an over priced holley sensor. It's a handy thing to have for sure.
Old 01-29-2022, 06:05 AM   #56
Paul Y
Gentlemen,
Only just discovered there is an LS section on the board so a bit late to the party!
Unlike the OP I am new to Both LS swaps and turbo but have been learning as much as I can over the past few years so when I started back on my truck last year I had the majority of parts and knowledge to get to the burn outs and ice cream stage as quickly as possible..
If you have not watched Matts series yet I would highly recommend it
https://youtu.be/X1v7b3ewAUg
Also watch this.
https://youtu.be/0NWLJt6SFwU
Bit out of date now but it is what I am using as my build recipe
Look forward to following your build.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
