12-17-2021, 12:19 PM | #3326 |
Re: PO has me PO'd
16397576828667733373477042964125 by [url=https://www.flickr.com/photos/97391199@N06
Had to add a 1" spacer to clear the clevis for the 'L' bracket to work
12-18-2021, 04:45 PM | #3327 |
Re: PO has me PO'd
WTH, why is there a M7x1 nut on my vent wing window....
16398592788818671975298718188069 by [url=https://www.flickr.com/photos/97391199@N06 Back story, after 4 weeks of buying nuts, to no avail, I humbled myself and called my son! Telling him of my problem, he said "is it metric?" I said, "It's a 1972 GMC jimmy, how could it be metric" so I gave him the OD, and pitch, he did some math, and came up with M7x1. I said thank you, wish I had called you sooner, instead of wasting 40.00 in nuts, he said At the cost of my engineering degree, you are way ahead.lol
12-18-2021, 04:59 PM | #3328 |
Re: PO has me PO'd
Time to clean up, no room to work
1639860982774515128196584128244 by [url=https://www.flickr.com/photos/97391199@N Tool box is almost empty
12-19-2021, 11:50 AM | #3329 |
Re: PO has me PO'd
Merry Christmas Jim .....been following along....
Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 12-19-2021 at 11:51 AM. Reason: more |
12-19-2021, 12:12 PM | #3330 |
Re: PO has me PO'd
finished and bolted front mount down, just have to design rear
16399297168096328773701209060490 by [url=https://www.flickr.com/photos/97391199@N06 Thank you Jess, and happy holiday season to you and your family as well Thanks for following along, are you still in NJ, thought I read you moved?
12-22-2021, 10:59 AM | #3331 |
Re: PO has me PO'd
16401849429525845957225115628482 by [url=https://www.flickr.com/photos/97391199@N06
All finished, just waiting on totally stainless to send me the cable clamps
02-15-2022, 12:19 PM | #3332 |
Re: PO has me PO'd
Valentines Day, my wife asked me if there was anything I needed for my truck. My immediate response was a BBWM, I called Ben at enegineed vintage and he had one in stock for a 67-72, should be here next week
02-15-2022, 12:35 PM | #3333 |
Can't wait to retire!!
Re: PO has me PO'd
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
02-15-2022, 12:52 PM | #3334 |
Equal opportunity joke ofender
Re: PO has me PO'd
That will look pretty good tucked up under the front
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-15-2022, 08:38 PM | #3335 |
Re: PO has me PO'd
can't wait to get started, dropped grille guard, bumper tomorrow
Thanks for checking in, Richard there's a name from the past, sorry I didn't respond to your PM, super busy, and wife needs some TLC
02-15-2022, 09:24 PM | #3336 | |
Re: PO has me PO'd
02-15-2022, 09:30 PM | #3337 |
Re: PO has me PO'd
[quote=jaros44sr;9008583]finished and bolted front mount down, just have to design rear
16399297168096328773701209060490 by [url=https://www.flickr.com/photos/97391199@N06 Thank you Jess, and happy holiday season to you and your family as well Thanks for following along, are you still in NJ, thought I read you moved?[/quote] sorry I didn't respond earlier covid went through here still in NJ down to one house 2 trucks and a wagon sold the Jersey shore house
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-16-2022, 10:28 AM | #3338 | |
Re: PO has me PO'd
Glad you still have the trucks and wagon, when the weather breaks, maybe I can get to see it. Wife and I do day trips to Brielle....
02-24-2022, 11:35 AM | #3339 |
Re: PO has me PO'd
1645716367716749474324302625392 by [url=https://www.flickr.com/photos/97391199@N06
Started install, mock up of the BBWM, just had to remove outside bumper bracket as bolt was interfering with mount, I was going to install winch mount with the bumper in place, but decided it was easier to get the bumper out of the way...... Nice part so far, just some of the bolts are not threading by hand, I may run a die on them, I plan to use low mount, since, I won't have to cut a hole in my nice bumper to mount a fair lead Thanks for watching Jim
02-25-2022, 08:19 AM | #3340 |
Re: PO has me PO'd
I was so excited to work on my truck today that I woke up at 4am
16457913320744443133232585760224 by [url=https://www.flickr.com/photos/97391199@N06
02-26-2022, 12:43 PM | #3341 |
Re: PO has me PO'd
Mocked up, feet up mount, called Warn, service tech said that a feet up mount requires a mod to the winch, apparently clutch and motor have to be switched from side to side, we'll see how that goes.........
16458932914272783050843789695736 by [url=https://www.flickr.com/photos/97391199@N06 Transmission jack was invaluable to get this winch in place Need to rotate winch 180 degrees
02-27-2022, 07:35 AM | #3342 |
Re: PO has me PO'd
This my winch mounting system, 3/8-16 hex drive studs with square nuts, much easier then trying to get bolts thru mounting plate lineup with feet and into square nuts. Held together with serrated flange nuts.
16459604620537441224320595081536 by [url=https://www.flickr.com/photos/97391199@N06 Time to grade product, I would say this is an A++ product, easy to install, great directions, answers texts in minutes, and very tough powder coating, plus no drilling or cutting involved. EV did his homework on this product Thanks Ben, for offering me this product Tools required, I would say your basic home shop, with a transmission jack,as floor jack seemed to be a little to unstable and didn't have the height Now, my least favorite part, wiring!, we'll see how that goes.......
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-27-2022 at 08:05 AM. |
02-28-2022, 09:18 PM | #3343 |
Too Dumb To Know Better
Re: PO has me PO'd
Looks good Jim. I bet that you are anxious to get it out on the trails.
03-01-2022, 08:27 PM | #3344 | |
Re: PO has me PO'd
Thank you, and it's good to hear from you, all good at home?
03-01-2022, 09:32 PM | #3345 |
Re: PO has me PO'd
All good athome. Looking forward to semi retirement,
03-02-2022, 10:01 AM | #3346 |
Re: PO has me PO'd
Retirement is great, lots of truck time, just a different lifestyle
Glad everything is good at home Just ordered my shackle mounts, was worried someone would steal my tow hooks, price of those has gone thru the roof
03-02-2022, 08:38 PM | #3347 |
Re: PO has me PO'd
03-03-2022, 08:19 AM | #3348 |
Re: PO has me PO'd
Good point
03-08-2022, 11:55 AM | #3349 |
Re: PO has me PO'd
Finished up the BBWM with the shackle mounts
16467544503011918812605666969812 by [url=https://www.flickr.com/photos/97391199@N06
03-08-2022, 11:58 AM | #3350 |
Re: PO has me PO'd
Had to modify end frame of winch to provide bleed holes for water
This is feet up mount 16466663267856965690023610472617 by [url=https://www.flickr.com/photos/97391199@N06
