Old 06-15-2021, 12:40 PM   #676
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
Thanks guys!
Originally Posted by LostMy65 View Post
So, you have 15x10's in the rear and 15x7's in the front?
That was a different set of rollers utilized during the build. The truck has 15x7" front and 15x12" Cragars on it now.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 06-15-2021, 03:56 PM   #677
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by racecougar View Post
Thanks guys!
Ok, that makes more sense. The tires are definitely wider in the rear. What tire size are you using?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-17-2021, 11:20 AM   #678
racecougar
racecougar's Avatar
The rear is a 31x16R15. I believe the front is a 235/70R15, but I'd have to check.
Old 06-17-2021, 02:18 PM   #679
LostMy65
LostMy65's Avatar
Thank you.
Old 12-19-2021, 07:51 PM   #680
racecougar
racecougar's Avatar
Had to run to Home Depot for a fitting last night. When I came back out to the truck, the sunset looked great, so I snapped a few pics with my iPhone. Wish I would've had a real camera and been in a better location than HD's parking lot, but for a total impromptu shoot, I think these turned out well.
Old 12-19-2021, 09:08 PM   #681
LostMy65
LostMy65's Avatar
Great shots
Old 12-29-2021, 10:43 PM   #682
racecougar
racecougar's Avatar
Thanks.
Simple improvement today. Ditched the rattle-prone, P.O.S. re-pop door checks for a pair of modified Jeep Cherokee door checks. I used the door checks for the front doors of a '84-'01 Jeep Cherokee. Benefits include two detents to hold the door open, they don't rattle, and if the rubber fails, they won't allow the door to smash into the fender.
Out of the box, the detents were too aggressive; they required so much effort to overcome that I was worried about breaking the clevis out of the door pillar. Additionally, the "full open" position was not quite open enough. Grinding/smoothing down the detents and cutting the rubber bump stops in half corrected both issues.
Repop door checks on the left and top, modified Cherokee door checks on the right and bottom.
Old 12-30-2021, 01:24 AM   #683
cwcarpenter98
cwcarpenter98's Avatar
Yup, I definitely need to do that door check mod to my truck. The repop ones I installed a couple years ago already broke
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
