Old 01-13-2022, 06:01 PM   #626
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Originally Posted by aggie91 View Post
Your truck is just outstanding! and now you made improvements. Sure hope to get to see this one in person someday.
Me too. Thanks for the positive comment.
I found out what was leaking. Once the timing cover is installed use THREEBOND 1217H sealant at the front of the timing cover lip, they are two piece and they are not sealed just spot welded so oil gets through.
Old 01-13-2022, 06:14 PM   #627
SCOTI
SCOTI's Avatar
Leaks @ the seam huh?
Seems epoxy would be a more permanent solution for where the spot-weld seamed pieces meet vs relying on silicone/sealant solely. Always wondered about this area myself as it seems both front & rear of GM based oil pans are chronic leak prone.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2022, 07:53 PM   #628
The Rocknrod
Moderator
Well she's back in the saddle again. Ran it for about 10 minutes. Still have to go get the exhaust hooked up.
Old 01-14-2022, 11:28 PM   #629
Joe Pass
Joe Pass's Avatar
Nice..........
Joe Pass is offline   Reply With Quote
Old 01-15-2022, 11:37 AM   #630
The Rocknrod
Moderator
Thanks Joe.
Removed the rear end cover and letting it drain, maybe tomorrow I'll re-install it with "The Right Stuff" after I get it all clean.
Old 01-15-2022, 12:05 PM   #631
SCOTI
SCOTI's Avatar
Thanks Joe.
https://www.lubelocker.com/products/gm-12-bolt-llr-g012
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2022, 12:33 PM   #632
Braunschweiger
What a great job, what a beauty, my greatest respect.
Greetings from Germany
Braunschweiger is offline   Reply With Quote
Old 01-15-2022, 01:39 PM   #633
The Rocknrod
Moderator
Thanks.
I actually have one of those.
Thank you for the positive comment.
Old 01-15-2022, 03:21 PM   #634
The Rocknrod
Moderator
So after snugging the bolts for the 12 bolt cover I used an inch pound torque wrench and started at 25 inch pounds. Per this post I then went to 45 inch pounds and it seems almost too tight. https://67-72chevytrucks.com/vboard/...51&postcount=2
Old 01-15-2022, 06:38 PM   #635
SCOTI
SCOTI's Avatar
I've never even looked up what the factory spec was. Always just snugged them up until I felt it was 'just enough'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2022, 07:41 PM   #636
The Rocknrod
Moderator
I normally do the same. I was just trying something new .
Old 01-27-2022, 04:56 PM   #637
The Rocknrod
Moderator
So I took it over to get the exhaust re-done due to the new manifolds at a local shop and on the rack.
Old 01-27-2022, 08:30 PM   #638
Joe Pass
Joe Pass's Avatar
Did it work out?...I always fool with the exhaust, I'm never satisfied with the sound...
Old 01-27-2022, 08:33 PM   #639
The Rocknrod
Moderator
I think it did, sounds just perfect for me. They really took theyre time on making sure it was run correctly. I'm happy with the work.
Old 01-28-2022, 08:17 AM   #640
clemdaddy
clemdaddy's Avatar
Beautiful truck!
It's a good morning when you can have your coffee and read through a few pages of a great build thread. Thanks you Sir, and good morning to you.
Time to heat the shop...
clemdaddy is offline   Reply With Quote
Old 01-28-2022, 12:15 PM   #641
The Rocknrod
Moderator
Originally Posted by clemdaddy View Post
Beautiful truck!
Thank you Clemdaddy, always good to hear from you.
Old 02-02-2022, 12:35 PM   #642
The Rocknrod
Moderator
I changed the jets and metering rods in my Street Demon to a tighter tolerance recently to get better mileage and my plugs showed signs of too fuel. I went two sizes smaller (not good).
Boy did I go too tight for my engine, I could hardly get down the street. I then put the smaller metering rod back in and was able to drive it, but it wanted to go into passing gear too much (looking for more fuel) when I sped up, I mean way more than normal. Plugs are now dry though
Now today I receive the next higher rods and jets, 2 main and 2 secondaries (and gaskets). Should be the ticket. Should have gone one size lower to begin with, live and learn I guess.
And wouldn't you know it. Got the parts, they sent One Jet in a package that was supposed to have two in a pack. They are sending me out a new set today.
Old 02-02-2022, 04:00 PM   #643
Joe Pass
Joe Pass's Avatar
This is how to decide on the tune....trial and sometimes error...lol....
Every once in a while I make an adjustment or two...just to return back to my previous settings. It just to me confirms where you need to be....Good work
Old 02-02-2022, 04:03 PM   #644
The Rocknrod
Moderator
Yes, with a carb like this metering rods and jets are all you have after you adjust vacuum, timing, idle. Takes time but I think I'll be happier doing it the hard way.
Old 02-08-2022, 04:36 PM   #645
88Stanger
88Stanger's Avatar
Damn Sir, that is one beautiful ride!!!! Great to see it on the road..
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 02-08-2022, 07:05 PM   #646
The Rocknrod
Moderator
Thanks, still waiting on a couple parts due to the local freeze UPS said there was a delay.
Old 02-10-2022, 04:36 PM   #647
88Stanger
88Stanger's Avatar
Figures.... Got to love UPS..... lol
Old 02-20-2022, 01:10 PM   #648
The Rocknrod
Moderator
I think I finally got that carb nailed down. Kept the 78's Jets and put in the 60-52 rods and she doesn't kick down when I get on the road all the time. Only when I make it kick down. I have to wait a while to report my mileage as right now it seems embarrassingly high.
Old 02-20-2022, 02:46 PM   #649
Paul Y
Mr Rod,
You have excelled yourself with this truck.
The stance, has been nailed.
Love it.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 02-20-2022, 03:52 PM   #650
The Rocknrod
Moderator
Originally Posted by Paul Y View Post
Mr Rod,
Love it.
P.
Thank you Paul, of course being my worst critic I questioned that for a while.
