01-17-2022, 03:41 PM | #801 | |
The Older Generation
Re: Project 67 DRGNWGN - 67 Burban!!
Yes, I would move those brake lines as far away as you can. It might not hurt to put some kind of heat shield on them too. It will heat the brake fluid up and expand it. If the fluid returns to the master cylinder that might not hurt anything but it locked the brakes up on my '36 Ford when it happened on it. LockDoc
01-17-2022, 05:38 PM | #802 | |
low n' slo
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-17-2022, 07:26 PM | #803 |
low n' slo
hand bent them a little more and its looking better. once i get my column back in i can dial it in and wrap the lines there.
im trying to get my stock ps lines to work with the ls steering pump. i think i can make them work if i shorten up the return hose line. but on the pressure line i do kind of have to worm it under the pump like the picture but i think it will be fine. i just need to either get a fitting adapter for the ps pump or see if i can get an original fitting from our style pump and swap them out. yall think these stock ones should work?
01-17-2022, 07:33 PM | #804 |
You should be able to get the right fitting from NAPN and get them to install it on your hose. Even the NAPA in my little town can do it.
01-17-2022, 07:38 PM | #805 |
low n' slo
the problem is there is almost no room to shorten this thing with the bend on the pump side fitting. im guessing they would have to cut the hose and crimp a new tube on it with the right bend and right fitting. can they do that? i have a napa about 15 min up the road from me
01-17-2022, 07:58 PM | #806 |
low n' slo
I pulled the fitting and oddly it seems to thread in. however, when it fully tightens the tube can still wiggle in and out some, like the it isn't sealed. the gear box side works perfect, both fittings snug down and don't move.
01-17-2022, 08:01 PM | #807 |
low n' slo
well i pulled the fitting from the ps pump and this line does thread in, but it does not seat the line. it threads about half way and gets snug, but the line still wiggles in and out. on the gear box side both lines snug perfect and lines dont move at all. last pic shows how far in the fitting goes before i cnt tighten it anymore. hmm...
01-18-2022, 04:51 PM | #808 |
low n' slo
ordered a fitting from amazon after striking out at the junkyard today. hope it works.
got my knock sensors and galley cover on followed by the intake. starting to look more like a motor. tons of room between the motor and firewall, love it. on this booster fitting, can it swapped from one from the donor truck? the ls hose is too big for the smaller booster fitting.
01-18-2022, 06:25 PM | #809 |
low n' slo
i did find a replacement booster check valve through amazon, but i went an easier way and just cut the ls hose and put a 1/2" to 3/8" hose reducer and ran 3/8" hose to the stock booster fitting. think it will work fine.
01-19-2022, 01:02 AM | #810 |
Take a look at this thread. This is what I used on mine. The little button adapters. http://67-72chevytrucks.com/vboard/s...d.php?t=242458 https://productpage-ui.vercel.app/O-...ter,24682.html LockDoc
01-19-2022, 09:56 AM | #811 |
Like you I have an early flare fitting steering box and a late model o-ring pump. The PO used an adapter fitting like the one shown in the thread LockDoc posted. I am fixing to tear it all apart and replace the pump and steering box this week. Let me know if you need some pictures or other help.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-20-2022, 08:25 AM | #812 |
low n' slo
ha that's a cool little fitting...didn't know they existed. I found an ls swap one that's supposed to replace the stock o ring style with the flare style. we will see if it works.
01-20-2022, 12:26 PM | #813 | |
That should work also. LockDoc
01-21-2022, 05:46 PM | #814 |
low n' slo
seems to work like a charm. heater bypass hose also came in. i think im about to order my radiator as well. i did order my fender bolt kit and core support bushing/mounts. plan is to get the front somewhat assembled with the fenders so i can let the truck off the jackstands and start setting it at ride height and see what i need to do about my rear bag mounts.
01-22-2022, 12:50 AM | #815 |
Good deal! Progress... LockDoc
02-06-2022, 03:39 PM | #816 |
low n' slo
nothing exciting really, ordered my big block radiator made by spectra...pn cu730 i believe. it was obviously too tall but i made it work. cut the stock top mounts and raised them up, and also sectioned them to fit snug on the radiator. had to trim the lower rad. mounting cups too...but i think it fits nicely. use the stock donor tahoe rad hoses. had to cut both of them down but i think they should work out. for the top mount i used a 1.5" elbow hose to a 1.5"x1.25" reducer fitting..with a steam line port.
working on trying to get the small block shroud to fit this thing. i think i almost got it so well see how that ends up. ordering up my trans lines fittings now and will be doing braided line. ya i know, i bounce all over the place
02-06-2022, 03:40 PM | #817 |
low n' slo
radiator hoses..
02-06-2022, 06:39 PM | #818 |
low n' slo
got the hoses all clamped up. really wish i had better looking clamps but oh well. got the intake "mounted" too but that will need some attention later when i get the fenders and fender wells on. its just hanging there since i didnt mount the box that holds it. ill look at some of you guys trucks and see if i might go in a different direction.
fan shroud is just sitting there for now, will need to find a way to attatch it
02-06-2022, 10:15 PM | #819 |
Looks like that should all work. I'm wondering how much hood clearance you will have with the radiator. I hope no problems there..... Good progress anyway. LockDoc
02-06-2022, 10:19 PM | #820 |
low n' slo
ya i really hope not lol. well, we know some of the c20s came with a big block from the factory, i just dont know what core support they used. hopefully within the next month or so i can get the inner fenders painted and install the fenders with the hood and see how it fits. cross that bridge when i get there i guess
02-07-2022, 12:55 AM | #821 | |
As far as I know all of the core supports were the same height no matter what year or what engine they had. LockDoc
02-07-2022, 01:50 AM | #822 |
A big block radiator is a little wider and thicker but No taller than small block or six cylinder radiator. It looks like you may have a square body radiator, I have used that size before with 69-72 style hood without clearance problems. but it wont clear 67-68 hoods. The top picture shows my spacers I used to make mine fit standing upright but the '67 hood would not close . In the second picture you can see I had plenty of room to tip the radiator back and mount at an angle allowing to shut the hood. I hope that helps.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-07-2022, 08:55 AM | #823 |
low n' slo
uh oh then I'm going to have problems with my 67 hood. I can't lean it back at all. this radiator is a squarebody one. do you know where it was hitting?
02-07-2022, 11:41 AM | #824 |
It hits on the support that goes across the front inner hood. I'll see if I can find a picture.
02-07-2022, 01:34 PM | #825 | |
