#51 |
Re: 30% More Powerful-New 1/2T Power Brake Sys
PayPal payment sent your way. Thanks and Happy New Year!!!
#52 |
Hi, I’m interested in this for a ‘68 GMC long-bed with drums all around.
Do you still have them available? Thanks… |
#53 |
Forgot to mention it is a 1/2 ton…
#54 |
I was wondering if you sell just the booster? I'm looking to replace a failed stock booster on my 67 1/2 ton and the smaller double diaphragm booster would be nice.
#55 |
"Trucks with Class"
![]() Join Date: Jul 2000
No parts for sale. Complete systems use coordinated parts and are not just stock replacements.
#56 |
"Trucks with Class"
Yes. Still building complete systems, as shown. I use new adjustable valves and lines on my Drum/drum units. These function as a Dist Block and fit really well. Note 2022 prices.
#57 |
What size is the booster and the master cylinder's bore diameter? And the system is 30% better than what? I assume that's relative to some of the aftermarket kits that don't properly size the master cylinder and booster.
I ask because my 69's stock 71-72 master cylinder, booster, and disc/drum brakes will just about put me through the windshield! That said, the factory did a much better job than the aftermarket does today. Way too many improperly sized boosters and master cylinders, and "one size fits all" fixed-pressure proportional valves used by default. I like that yours was designed specifically for our trucks, and fits without mods.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 02-16-2022 at 01:36 PM. |
#58 |
"Trucks with Class"
The booster is 9" dual diaphram (DD), new, built for our systems. It is 30% more powerful than original OEM 1/2T. Other components are selected and fitted for our specific truck applications, not some universal off-the-shelf car parts. You cannot buy this system in catalogs or web sites.
#59 |
The dual 9" booster answers my question! That's a good way to go. Funny that some kits have dual 7" or even a single 8". Downside is you may put some guys through the windshield.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#60 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Sending PM with questions
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#61 |
Frank, what is the reference to "MO" above? I see you're in WA, does it reference Mail Order or Missouri? I'm in Missouri and why I'm asking.
#62 |
"Trucks with Class"
MO = Money Order
#63 |
"Trucks with Class"
'2022 PRICES: $375 + $75 S/H/INS =
I split the increases with you. |
#64 |
![]() Join Date: Mar 2011
Frank
my 71 has manual MC I want to upgrade to your unit I have a mild cam in my 327 im assuming that should not pose a vacuum problem ? disc /drum thanks Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-24-2022 at 09:06 PM. Reason: more |
#65 |
"Trucks with Class"
Mild cam should be OK.
#66 |
MP Brakes says you need 18" minimum idle vacuum, but I think that's conservative. That number will vary with caliper and pad type, as well as booster area and vehicle weight.
The kit listed in this thread uses two 9" boosters, which is a lot of diaphragm area! So I'd say 16"-18" should be fine, assuming your calipers, pads, rotors, drums, shoes and hoses are in good shape. Otherwise it's like installing a performance cam and a new carb on a worn-out engine.
#67 |
![]() Join Date: Sep 2005
how does the pedal higheth compare to the manual brakes? i tried swaping to power brakes once and never could get a decent pedal and it sit like 2 inchs lower then the manual setup.
#68 |
"Trucks with Class"
It sits in the same location as the stock/OEM PB pedal.
#69 |
I would like to order one for my Jimmy
#70 |
"Trucks with Class"
I have all the components in stock. Just send PP with all info.
Thanks, Frank |
#71 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#72 |
Tag
#73 |
![]() Join Date: Jan 2011
Sir, are these still available?
70 Custom 10 350 w/700r4 (current) 69 Custom 10 I250 Three on the Tree 72 Cheyenne Super 350 66 Ford F100 I240 Three on the Tree 72 Chevelle Malibu 402 66 Pontiac Catalina 421 65 Ford Fairlane 500 |
#74 |
![]() Join Date: Jan 2002
Are these still available? If so, I will take a complete set-up.
Posted via Mobile Device |
#75 |
"Trucks with Class"
Yes. All components are back in stock and I am building & shipping these regularly. Just send PP to below address. Thanks, Frank
