03-12-2022, 09:27 AM | #1476 | |
Watch out for your cornhole !
Re: How about some pics of 88-98 Part II
Rear 4 inch Belltech drop leaf springs. Belltech shocks. 275/60-15 on 8 inch rally wheel. I chose coils in the front over spindles so I didn't have wheel interference issues and the need to trim the lower arms. In the back I chose the drop leaf springs because they are way easier to install than drop hangers and shackles and also it addresses the inevitable lean or unlevel sag that these trucks get in the back as they get older.
03-12-2022, 03:02 PM | #1477 |
laying low
It's got that just right stance. I've not bought lowered leaf springs before but I did once or twice heat some a little near the ends. It was just a 1/2 ton shorty and it never hauled anything much.
03-12-2022, 03:41 PM | #1478 |
My experience with lowered leaf springs have all been Belltech.
I have run two sets of them on GMT400 trucks, including this one. And I ran a set on a Ford Ranger I built a couple of years ago. They flat work and they fix any bit of out-of-level the trucks have. People underestimate how much leaf springs sag over time and then say "Chevy lean, they all do that". Not with good leaf springs they don't. And it beats all to hell having to remove the riveted on hangers for a typical 4 inch rear drop.
03-12-2022, 03:44 PM | #1479 |
03-12-2022, 06:20 PM | #1480 |
My two pieces…..
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
03-16-2022, 07:50 PM | #1481 |
My 1989 C3500 Ramp Truck with a 454 and turbo 400 doing what it does. Pics are from Daytona Turkey Rod Run.
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
03-16-2022, 08:13 PM | #1482 |
Very nice hauler. Is that a Hodges body?
03-18-2022, 11:56 PM | #1483 |
On the road
My 98, I bought this truck when it was 2 years old. It's like part of the family.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
03-19-2022, 07:57 AM | #1484 |
Very sharp!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
03-19-2022, 08:49 AM | #1485 |
Really nice! Goes to show how a well designed vehicle stands out. A little extra rubber to set it off as being special to the owner and kept up is all they need. They look good all by themselves
03-19-2022, 07:33 PM | #1486 |
laying low
An update to my ‘91. I have had these Outlaw wheels for 20 years and this is the 3rd truck they’ve been on.
03-19-2022, 08:02 PM | #1487 |
Looks good!
03-19-2022, 08:38 PM | #1488 |
I got a new factory GM 88-93 grille and lights for my truck. Then I finally found some 88-89 sealed beam assemblies in the junkyard. So I converted my 97 model work truck front end to an 88-89 Silverado quad sealed beam front end. The GM grille is so much nicer than aftermarket. i had to save my money a long time to get all the new factory parts. One area I cut corners on was buying a billet grille emblem rather than a new OEM one. GM gets eye watering money for new original grille emblems.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 03-19-2022 at 09:03 PM. |
03-19-2022, 08:41 PM | #1489 |
Looks great with the W/T smoothie bumper Kevin!
03-19-2022, 08:48 PM | #1490 | |
03-19-2022, 09:01 PM | #1491 | |
Thanks bud.
The turn signal lights below them are different too. They have black trim around them rather than silver like the 90-93 uses. And they mount on special 88-89 only brackets which go between the grille shell and the light housings to space them out further.
03-19-2022, 10:04 PM | #1492 |
Nice detail. I always noticed the difference and preferred the early bulb set-up.
03-19-2022, 11:28 PM | #1493 | |
I always thought it was odd my 93 grille has the molded in feature for the sealed beam headlights. It's barely noticeable unless you look for it though.
03-20-2022, 12:09 AM | #1494 |
laying low
Glass headlamps are better in my eyes. They don't yellow and scratch. I converted my old 97 GMC to 88 sealed beam lamps. I liked it much better and all I ever did was wash them.
Kev I am surprised GM still offers those grilles. Good to know though. I may have to snag on some sealed beams for my 91 when the time comes.
03-20-2022, 08:05 AM | #1495 |
It makes sense on a '93 grille since it's the same grille as the '88-'89 trucks that came with the sealed beams. The '94-'98 grilles are also shaped that way, even though those grille styles never came with the quad sealed beams.
03-20-2022, 10:38 AM | #1496 |
My '95 Suburban has factory sealed beams
03-20-2022, 12:09 PM | #1497 | |
That's so funny! I went to check my 99 all prepared to call BS and you're right. I never looked for it on that one, I assumed it didn't have it. It is less pronounced though.
03-20-2022, 02:20 PM | #1498 |
I ran an ad on Facebook for the old parts, cheap. No interest from anyone so to the dumpster they go. I don't like to keep too much clutter around.
03-20-2022, 04:01 PM | #1499 |
Some of us avoid FB....
03-20-2022, 04:54 PM | #1500 |
I've deleted it multiple times but I go back to it. There's nothing else that's active anymore. I hate it with a passion but a man's got to buy and sell.
