02-02-2017, 09:32 PM | #1 |
Radiator Support bushings
Hey guys, I'm just doing some mock up on my '64, after rust repair to the cab, doors and fenders. Doors line up nice but the rad support seems to be sitting high and messing with fender/door gaps.
Wondering if this is the proper way the bushings go under the rad support? (I know they're old and gnarly but I figured since I didn't do the cab bushings things would go back into place how they were) |
02-02-2017, 11:56 PM | #2 |
Re: Radiator Support bushings
those look good (BUT You may have the steel and rubber reversed) sounds like you need to shim the front cab mounts
02-03-2017, 12:16 AM | #3 |
Okay thanks for clearing that up for me. Never considered shimming up the cab at the front. Would that also change how the rear of the cab lines up with the box?
Think it'd be harmful to remove the thick steel washers all together? That might bring the front down enough. . |
02-03-2017, 01:33 AM | #4 |
60-66 Nut
I'm pretty sure there should not be a thick washer on top of the frame bracket.
02-03-2017, 02:13 AM | #5 |
mine didn't have a washer sitting on top of the frame, it was just the bushing
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-03-2017, 07:59 AM | #6 |
Well that's good to hear, knew I should've taken some pics before removing it. Thanks!
02-03-2017, 08:58 AM | #7 |
Moderator
02-03-2017, 11:05 AM | #8 |
Here is the full thread that Rocknrod referred to http://67-72chevytrucks.com/vboard/s...82#post5818882
02-03-2017, 03:25 PM | #9 |
Moderator
I knew I had the instructions to the kit I bought:
02-03-2017, 10:21 PM | #10 |
Thank man, looks like I have it set up correctly except for the bottom washer.
Maybe I am gong to need to shim the cab |
02-04-2017, 01:04 PM | #11 |
I'm gonna replace the cab mounts and see if that fixes this. They're 50 years old anyways.
03-23-2022, 08:57 PM | #12 |
C10 CLUB Y QUE!
I have the brackets that have a thick rubber on them. Can I replace them with the bracket that doesn't have a rubber on it?
03-23-2022, 10:08 PM | #13 |
Moderator
I've not seen ones like that so what do they look like?
03-31-2022, 11:02 AM | #14 |
C10 CLUB Y QUE!
It still takes the above material but it has an extra hard rubber between the bracket and the frame. ill take a picture tonight. |
