Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-03-2022, 01:08 AM   #26
Sand Wrench
Sand Wrench's Avatar
Re: 1972 K10 Ebay Truck
Weld-thru primer on all the seams and concealed areas. Reinstalled mount plate and forward cab support. I didn't like the outside shoulder on the forward cab repair panel, so I cut it down and mated it to the one piece outer floor extension panel, LMC P/N 38-7905. I've used it a couple times now, and I really like how it mates to both NOS and aftermarket outer rockers. Added approximately 20 lbs of .023 ESAB Easy-Grind MIG wire, ground off approximately 19.9 lbs of the aforementioned wire, and voila, starting to look like a truck floor again!
You ever have one of those mornings where you wake up owning more trucks than you did the night before?
1972 K5
1972 K10
1967 K20 bucket truck
Sand Wrench is offline   Reply With Quote
Old 03-03-2022, 01:20 AM   #27
Sand Wrench
This truck is turning out too nice to use aftermarket rockers, time to hit the NOS! Test fits like a glove.
1972 K5
1972 K10
Old 03-03-2022, 01:52 AM   #28
Richard
Good progress on the metal work. Looks nice.
Richard
Old 03-03-2022, 09:29 PM   #29
Sand Wrench
Blasted rockers, masked seams and sprayed epoxy on the interior. Followed with a coat of weld-thru primer on the seams.
1972 K5
1972 K10
Old 03-03-2022, 10:06 PM   #30
Sand Wrench
Blasted the belly, coated with epoxy, and put on 2 coats of Raptor Liner.
1972 K5
1972 K10
Old 03-05-2022, 11:11 PM   #31
Sand Wrench
Houston, the yellow has landed! Cream yellow with flattening agent to match the faded 525 GM yellow. Get it a little dirty and no one will ever know
1972 K5
1972 K10
Old 03-07-2022, 12:02 AM   #32
layinrocker65
layinrocker65's Avatar
Looks really good
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 04-26-2022, 02:45 AM   #33
Sand Wrench
Cleaned and primered the window frames, installed new window glass and the original trim. It was a challenge.
1972 K5
1972 K10
Old 04-26-2022, 03:53 PM   #34
LostChord
Hahaha...looks great!
LostChord is offline   Reply With Quote
Old 05-01-2022, 03:51 AM   #35
Sand Wrench
Got my seat torn down and re-upholstered with new foam and a seat cover from Cars Inc. in Detroit. Original pattern for option 601 Black Cloth Trim.
1972 K5
1972 K10
Old 05-01-2022, 05:23 AM   #36
jjzepplin
jjzepplin's Avatar
Good progress! Looks nice and fine work sir!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-22-2022, 10:25 PM   #37
Sand Wrench
Got the lower cowl and floor insulated.
1972 K5
1972 K10
Old 05-22-2022, 10:43 PM   #38
Sand Wrench
Couldn't resist shifting gears and working on wheels and tires. Wheels are CUCV 15x8.5 steelies. Blasted the rims to bare steel and pre-baked them at 450. Hot flocked a coat of Prismatic zinc infused epoxy powder, then top coated with urethane powder as soon as it flowed out. Tires are 33x10.5 BF Goodrich All Terrain T/A's.
1972 K5
1972 K10
Old 11-02-2022, 01:09 PM   #39
Sand Wrench
Finally got the engine components back from the machine shop and started putting it back together. Setting it up with 9.0:1 compression, Comp 206/212 roller cam, full roller rockers, Summit 2.5 inch iron exhaust manifolds, and a stock iron intake. Planning to use a Quadrajet for a somewhat stock look (if you can ignore the extra tall valve covers).
1972 K5
1972 K10
Old 11-02-2022, 10:03 PM   #40
Getter-Done
Getter-Done's Avatar
Is there a gear drive under that Timing chain cover?
84 Chevy K-20
Old 11-02-2022, 11:55 PM   #41
Louisvillekytruck
Great project
Louisvillekytruck is offline   Reply With Quote
Old 11-03-2022, 12:37 AM   #42
Sand Wrench
No, I went with a Comp CCA-7100 double roller chain. The timing cover is a Cloyes two piece with an adjustable roller cam button to set the cam lash. https://www.cloyes.com/high-performa...-timing-cover/ . I would not use this cover again, it doesn't clear a short water pump, so I had to shim the pump and the accessory pulleys.
1972 K5
1972 K10
Old 11-10-2022, 01:22 AM   #43
chev-obsession
chev-obsession's Avatar
This is a cool project and a cool story how you got it home
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-18-2022, 12:29 AM   #44
Sand Wrench
On to the greatest transmission ever built, the granny low SM465! I had a lot of slop in the driveline due to worn splines, so I replaced the transmission main shaft and the coupler sleeve. Also installed the upgraded third gear and countershaft spacer to prevent the transmission from popping out of third. I rebuilt the top cover with new shift forks and ordered the one piece shifter from Novak. Hopefully it will be a nice tight shifting transmission!
1972 K5
1972 K10
Old 11-18-2022, 11:57 AM   #45
landarts
landarts
Excellent work on the truck. Watching the SM465 rebuild. I need to do one for one of the K20's.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-06-2022, 09:40 PM   #46
Sand Wrench
NP205 overhaul complete; with parts, tools and tech data from Torque King. I replaced the 10 spline input shaft as well as the bearings. I think a lot of that "klunk" that you hear on these manual transmission trucks is connected to the 10 spline coupler between the transmission and the transfer case. I replaced my coupler and both shafts, so I'm hoping to have a nice tight drivetrain for years to come.
1972 K5
1972 K10
Old 12-06-2022, 11:08 PM   #47
Louisvillekytruck
Nice work
Old 12-09-2022, 06:27 AM   #48
jjzepplin
jjzepplin's Avatar
You are correct. I took my 70 apart and found the output shaft of the trans was worn like crazy and the coupler must have been just bouncing around in there as it was bad on both ends. I think I put a good amount of synthetic grease on my shafts of the 203-205 setup I have now. It was a long time ago.
Old 01-13-2023, 02:29 AM   #49
Sand Wrench
Frame cleaned up, powertrain reinstalled, cab back on. Starting to look like a truck again!
1972 K5
1972 K10
Old 01-17-2023, 03:15 PM   #50
gmikkels
Hello,
Did you like the summit exhaust manifolds?
Thanks,
Gene
gmikkels is offline   Reply With Quote
