Found this rare gem!
It looks like I have a project. A 1965 K15 stepside longbox with optional 292. SM 420, and Rockwell T221. Engine is seized. Transmission and transfer case both shift fairly easily. Clean oil in both with no metal that I can see. It was a miners truck in Merrit BC. I don't think he drove far down the road after lighting the fuse! Dented everywhere, floor is rusted out, but the fenders etc are pretty solid.The truck has been in a field in Langley for 15 years. Pretty rare, it looks like only 513 units built of that type in 65.The PO cut a notch out of the front cross member to make room for the PTO driveshaft. UGHH But ,this thing is so cool. Not sure why the bottom pics went on their side...Oh well. Rick
Moderator
![]() ![]() Join Date: Aug 2011
Re: Found this rare gem!
Wow that's cool, great find.
Thanks, it looks like everything exept the bumpers are original. I’ll post more pics as I get it stripped down. I’d like to keep the PTO and winch but not sure if I can find one with a drop to go under the crossmember, or just keep it as it is. Rick
Posted via Mobile Device |
Yep, you have a project. It will be worth the effort.
Life hit him hard, great project
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
![]() Join Date: Mar 2013
Nice find!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() ![]() ![]() Join Date: Jan 2018
That one has a cool history behind it.
The front bumper looks to be an original that was cut for the winch. The rear was most likely a dealer option bumper from when it was new
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
