S10 frame swap 1950 GMC lowering block size?
Just about done my swap 1950 GMC LS/4l60E and now my rear looks too low to me. I used the frame mounts from skymangs post, and have drop spindles in the front. My current rear lowering block is 3" thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
Re: S10 frame swap 1950 GMC lowering block size?
I'd stick a jack under the back bumper or frame and raise the back up to where I thought it looked right and measure the difference at the center of the wheel well and go from there. That probably isn't more than one/two inches.
I used 2 inch drop spindles and 2 inch lowering blocks, with 15 inch wheels, if that helps?
it's kind of trial and error as it depends on your cab mounts
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
![]() Join Date: May 2007
do you have the wheels you plan to run mounted yet? I always set up a staggered set with different offsets and heights front to back, so a 3/3 drop always works out to a 3/2 or 3/2.5 and a roughly level ride height. that said, if you feel the rear is too low, and you have been driving a little and the front springs have fully settled, just go to a smaller block. (while I am thinking of it, make sure your front springs are seated! holds more guys up, literally, than they like to admit)
Thanks Gents..
I think the rear springs of the S10 frame have sagged..The previous owner used it as a scrap hauler and always had a load on it. I am going to cut my 3" rear block in half and see how it looks.
I wish I removed and replaced my rear leafs when I had the truck apart. The ride is a little stiff and I think that would help smooth it out. (they are probably seized)
Now that the truck is all together, I really don't feel like doing it. Looks great, keep at it
