07-13-2022, 03:47 PM | #1 |
Brake Booster Check Valve Grommet
Well...Here I am yet again, at my wits end trying to find the proper grommet for the brake booster check valve grommet. Try and try as I might, I cannot seem to get people selling these things to give me the diameter that actually matters in determining if the thing will fit the hole. The portion of rubber that sits outside the hole, either inside or outside the booster itself, is completely irrelevant. Rant over.
Speedway Motors Part Number: 92618599 Last edited by schovil69; 07-13-2022 at 04:30 PM. |
07-13-2022, 07:11 PM | #2 | |
Re: Brake Booster Check Valve Grommet
07-13-2022, 07:26 PM | #3 |
If I'm not mistaken...I've seen those at my local NAPA store in the HELP section along with a new check valve. They also carry the vapor filter used on the newer trucks
07-14-2022, 12:12 PM | #4 | |
Now we just need to get the industry providing those measurements when selling the grommets. Some do and some do not. The Speedway Motors part number I posted does have those measurements yet other grommets on their website do not. I'm blown away that the overall outside diameter is what is most often used to describe these things. |
07-14-2022, 01:23 PM | #5 |
The Dorman 80189 comes with the new check valve and two grommets of different sizes. Dorman 80191 is just the two grommets. Below is a link to Online Tube where they sell a 64-78 all models check valve and grommet. If you check the Dorman site it has grommet outside diameter listed
https://www.inlinetube.com/products/...yABEgILavD_BwE
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
07-14-2022, 05:09 PM | #6 | |
07-15-2022, 10:33 AM | #7 | |
07-15-2022, 11:28 AM | #8 | |
My trucks not factory power brakes. I have a aftermarket conversion on mine not sure if the measurements of mine would help. What year is your truck? I will still see if I can come accross any more
