07-10-2022, 05:22 PM | #2976 |
Who Changed This?
Re: What did you do to your truck today.The 3rd chapter
Lookin' good! Now, go put a scuff mark on it before someone else does!
07-10-2022, 06:42 PM | #2977 |
Spent about an hour a night for the past week and a half fixing the two lower corners of my windshield so I can get the glass installed. Took advantage of the opportunity and repainted the top of my dash. Shade is just a bit darker than the fawn interior. Also cleaned up the entire pinch weld area, primed, and painted with a flat black since the glass seal will cover pretty much all of it. Cleaning all the old goop off it went to the metal in a lot of places and I didn't want to leave it that way.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
07-10-2022, 07:45 PM | #2978 |
Who Changed This?
Youngest bro and I (mostly him) made two replacement springs for my truck seat. I'll paint the seat tracks tomorrow, and install them onto the seat bottom and dope out how the release works...or just leave it all the way back. Short stuff wife can't drive it that way though.
07-10-2022, 07:48 PM | #2979 |
Was that one you had laying around, NOS, or repop from a parts company?
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
07-10-2022, 08:01 PM | #2980 |
07-10-2022, 09:44 PM | #2981 | |
I'm planning on installing a quick ratio steering gearbox. While I'm at it, I'm going to replace my current one piece decapitator steering shaft with a newer two-piece style with an intermediate shaft. Will improve safety, and will make removing and installing the column easier. I cleaned up and painted an intermediate shaft I bought from Jeff's Bowties. |
07-10-2022, 10:24 PM | #2982 |
The only thing I did was install an NV4500 and a 6 bolt round pattern twin stick NP205.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
07-11-2022, 09:51 AM | #2983 | |
I have a steering box, pump, and bracket from a 73-74 model truck and think swapping to power steering will be a winter project this year. Just gotta figure out which bottom pulley I need for my 283.
07-11-2022, 09:20 PM | #2984 |
Got my windshield washers working and put the cowl back on with the wipers all together. Got my helper with me tonight.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
07-12-2022, 12:46 AM | #2985 |
I received a new brake line kit and got it ready to install them on the truck, but noticed something that I need to address. The studs from the brake pedal assembly are getting very corroded, and need replaced. Where can I buy a new brake pedal assembly? All that I can find are just the brake pedal lever, but not the mounting bracket. Thank you for any assistance that you can provide.
07-12-2022, 09:50 AM | #2986 | |
07-12-2022, 11:08 AM | #2987 |
What did I do with my truck, today? I stood there and looked at it wishing it wasn't so damned hot. Day after day it has been in triple digits with heat indexes over 110. This heatwave is unusual, even for us, this time of year. Some cars shows are being cancelled or, times being moved to earlier AM or later PM.
07-12-2022, 11:24 AM | #2988 | |
https://www.classicparts.com/1969-74...tinfo/CP-2032/
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
07-13-2022, 04:52 PM | #2989 |
New glass!!!! Truck is filthy but the glass is in at least.
07-13-2022, 09:45 PM | #2990 |
Who Changed This?
Got the seat backrest done. I'm trying to figure out how to compress that foam so that I can pull the cover over it and put in the hog rings on the bottom part. I wonder if they use some sort of squeeze machine in the upholstery shop? I need about 5" of "stretch" to get the cover to the back side attachment wires. My brother says to start at the back. Given that I'm not an upholsterer, I'm tempted to ask for mercy at a local shop.
07-14-2022, 03:06 PM | #2991 |
New clutch fan . Old one wasn’t doing a damn thing . Truck is running normal temps again at lower speeds . Highway wasn’t a problem as the fan doesn’t do at that much at 70mph
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-15-2022, 10:11 AM | #2992 | |
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-17-2022, 05:47 PM | #2993 |
Finally made some time for the 68 Stepper . I think they greased this truck every month . The grease and South Carolina red dirt was caked at least an inch thick on everything . When I started there was no lip on the control arm .
07-17-2022, 08:04 PM | #2994 |
Right on Mark, when I got my old Chevy the valve cover gaskets were leaking so bad it saved things from rusting out, either way it's all good......
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual Last edited by Jiggers72-GMC; 07-18-2022 at 09:19 AM. |
07-19-2022, 06:07 PM | #2995 |
70+ ( Old Skool Club )
Got the new engine primed and almost ready to fire up.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-20-2022, 03:47 PM | #2996 |
Dropped it off at the fab shop as a lwb. Hopefully picking it ip as a swb in a couple weeks.
Posted via Mobile Device |
07-20-2022, 08:05 PM | #2997 |
luv a sbc, nice work on smoothing out the exhaust manifolds
07-21-2022, 04:16 PM | #2998 |
Ordered new wiper blades and a washer bottle/pump for a mid 90's S10 with the intentions of getting the wiper/washers functional when it gets cool enough to work in the shop. Also working on stereo system. Maybe end of September.
07-23-2022, 10:54 PM | #2999 |
Bought another set of NOS upper trim to get the one I needed for the bed, installed Wednesday. Today I replaced mufflers and tailpipes.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
07-24-2022, 09:34 AM | #3000 |
Wow you got your own exhaust pipe bender. Nice!
