07-16-2022, 05:53 PM | #1 |
Where did you relocate your battery to?
Where did you put your battery? Can you share some pictures and/or insite? I really do not like the look in the stock position.
Posted via Mobile Device |
07-16-2022, 06:26 PM | #2 |
Re: Where did you relocate your battery to?
Behind driver's seat. I'm not overly happy with the location though. I bought a drop-down battery holder to mount to the frame but for some reason it doesn't fit. I need to revisit that idea.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-16-2022, 07:44 PM | #3 |
Under the cab on the frame with a drop down box. Had to cut the clamp bolt down because it ran into the bottom of the cab. It can be a bit of a pain to service it so I keep a new battery in it. You will want to make sure you have a connection for a charger somewhere that’s easily accessible. I also put some heat shielding on my exhaust since it was so close.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
07-16-2022, 09:41 PM | #4 |
I'm going to put mine behind the seat and use a battery intended for a 2000/2005 Cadillac Deville DTS. The battery is under the back seat of those and pretty low profile and is vented to the outside though tubes going though the floor.
07-17-2022, 12:30 AM | #5 |
Will run Red Top rotated 90 deg.
07-17-2022, 12:57 AM | #6 |
Behind pass seat
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-19-2022, 02:00 PM | #7 |
On the frame on the passenger side, behind the cab mount. Used a 47-54 patch panel to put a removable door in front of the seat on the passenger side hidden under my floor mat.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
07-19-2022, 06:23 PM | #8 | |
