Old 08-05-2022, 08:54 PM   #1
bcfishon
Computer mounting location
Swapped in a 5.3 in the 67 GMC k10 and was curious where others mounted the computor , I would like to mount it under the drivers seat but not sure the harness will b long enough.
bcfishon is offline   Reply With Quote
Old 08-05-2022, 10:05 PM   #2
Ziegelsteinfaust
Thumbs up Re: Computer mounting location
You can get long harnesses.
I am going to do a 24x swap on my gen 2 LT1, and plan to put it in the corner next to the master cylinder.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-06-2022, 04:51 PM   #3
LS short box
I put mine behind the glove box. I had to section the glove box liner a bit to make it fit. Standard ECM harness.
Old 08-07-2022, 08:29 PM   #4
Accelo
Accelo's Avatar
If you have AIR, or plan to, behind the glove box will not work.
I mounted mine by the RH hinge on the firewall.
Wiring is between the fender well and the cab.
I got it to fit by loosing the inter fender screws and installing the wiring.
It isn't going anywhere because it cant.
Had the same issue dictated by a modified harness not a full on replacement.
I can be seen in the top left of the picture.
It doesn't even come close to interfering with the hood hinge operation.
Accelo is offline   Reply With Quote
Old 08-08-2022, 08:42 AM   #5
Willie Makeit
Willie Makeit's Avatar
backside of the radiator support. Easy access, completely out of sight and practically no one ever notices it plus most factory GM harnesses are long enough that no lengthening is required.
Willie Makeit is offline   Reply With Quote
Old 08-08-2022, 05:03 PM   #6
Davidf
I mounted mine inside the fender, ahead of the fender liner. Basically the backside of the fender turn down that the washer bottle is mounted to...just ahead of the washer bottle. Donor harness is perfect length. Mounted the fuse box to the inner fender.
Davidf is offline   Reply With Quote
Old 08-08-2022, 05:07 PM   #7
Accelo
Accelo's Avatar
Both good options. My harness was a Corvette and it was too short for any of the great places you both mentioned.
Old 08-08-2022, 10:19 PM   #8
sfont66
sfont66's Avatar
I originally had intended to mount my GM ECU /ECM computer under the dash. But in the end it was so hacked up by the auto salvage yard, I was forced to look at other options. I ended up with the Holley terminator x. As it turns out , the harness has plenty of length to mount the ECU under the bench seat on the passenger side.
I ran the harness down the back side of the engine along the underside of the transmission tunnel, and up under the passenger side of the bench seat.
Just an option for those with a hacked up harness, or no harness or those thinking of hiding the ECU and wiring a bit
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 08-10-2022, 02:21 PM   #9
kev2809
low n' slo
kev2809's Avatar
i dont have stock inner fenders, but i did make some tubs. with the stock wiring i couldnt get it to reach far at all, so mine is going on top of the fender well...along with the mini fuse box and pedal box. if you had a driver side battery tray, it will fit there. almost did that but went with the fender mounting.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-10-2022, 05:12 PM   #10
LS short box
I try to hide as many wires as possible. ECM and relays in the cab. In the attached pic you can just see the ECM wire loom behind the right coil cover.
Old 08-10-2022, 05:56 PM   #11
bcfishon
I really appreciate all the input, the more the better and unfortunately I still have the factory heater core suit case so the passenger side firewall is a no go but I do like it!!!
Old 08-10-2022, 06:22 PM   #12
kev2809
low n' slo
kev2809's Avatar
clean! i dont know how you guys hide the wires like that lol
-_--_--_ _________
Old 08-11-2022, 05:05 PM   #13
LS short box
For the LS wire harness you can pull most of the wires to the back of the engine. They will fit under the plastic coil covers.
The chassis harness to the front I ran down left frame rail.
I used used a Painless universal chassis harness. I filled the the stock fuse block hole. Then moved the Painless fuse block back a bit and then made a small hole you can't see to run the front chassis wires forward along the frame rail. The Painless wires are plenty long enough.
Here's a pic of my current 80 Camaro LS3 swap.
Old 08-11-2022, 05:35 PM   #14
kev2809
low n' slo
kev2809's Avatar
very clean I think my next go round I'll will have to try something like this
-_--_--_ _________
Old 08-13-2022, 07:12 PM   #15
mongocanfly
mongocanfly's Avatar
i used psi harnesses on 2 trucks. neither harness will reach under the seat,, that leaves under hood or inside cab on firewall.. i have the one on my 81 behind the glovebox
i even contacted psi about making me a harness with a longer tail..no dice..the next one i do will probably be with a bp harness.. everyone says its long enough to reach under seat..
we will see.. my next project will have a/c so i know there wont be room under dash
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-13-2022, 08:32 PM   #16
bcfishon
I hate anything under the dash,tough for the old and stiff to access and its a tight area for tools to work in,unless your starting from scratch.
Old 09-01-2022, 09:38 PM   #17
Accelo
Accelo's Avatar
If the wires allow it mounting the ECM between the battery and the core support works well for a lot of people. Hidden but still stays cool.
Cheers.
Old 09-02-2022, 08:21 PM   #18
Blazerowner
Blazerowner's Avatar
Wanted to post my location. Under the dash near the wiper motor. I did use the radio mount holes but I don’t believe I will need them with my retro radio. Bear in mind this is a Holley terminator ECU but any ECU should work here.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 09-10-2022, 08:42 AM   #19
fast70swb
Hard to see but I made a mount that slides in/ out and put my behind my restomod heater/ ac box
Can get better pictures if needed
fast70swb is offline   Reply With Quote
Old 09-11-2022, 08:43 PM   #20
v30crewcab
v30crewcab's Avatar
my bp harness reached under the pass seat. nice and clean. ran the harness down the trans and up into the floor. 1971 c10
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-15-2022, 10:04 PM   #21
bigmoe
bigmoe's Avatar
Ideally, I would put it under a seat or console if the harness will reach.
I have a reworked factory harness that is routed off the driver's side of the motor so I put my Gen IV ecm as far forward on the inner fender as I could. It's partially hidden by the air filter.
bigmoe is offline   Reply With Quote
Old 09-16-2022, 05:46 PM   #22
gt40racing
gt40racing's Avatar
Got any pictures of the Terminator X mounted? At what point did you come through the floor?
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1966 Mustang Coupe GT
1965 Fastback Mustang
1951 F1 Truck
gt40racing is offline   Reply With Quote
Old 09-16-2022, 07:56 PM   #23
sfont66
sfont66's Avatar
I have a couple of pics saved, the Terminator X ECU I don’t have mounted yet. It is just tucked under the seat, and the wiring harness holds it in place fairly well for now. I will most likely make a permanent mount later. I plan to remove the seat and carpet this winter and add some sound deadener/ insulation under the carpet, so the seat and carpet will come back out.
Anyway a few pics….
The first one will give you an idea of the location of the for the 2” hole required for the main harness. The power harness, I ran through an existing hole previously used for the fuel tank.
The second pic is from below, the harness was routed to the back of the engine, then down along the underside of the transmission tunnel, and up into the cab,in my case I have a high hump, I removed some of the transmission cover bolts, and replaced the bolts with longer ones, and used the longer bolts to secure both the cover and cable clamps.
The third pic is just an engine pic, but it shows how little of the harness shows, there are more ways to hide wires, but I was running out of time, and a lot will have to come back off , if I do end up doing a color change to hugger orange in the near future.
Hope this helps,
Old 11-14-2022, 01:36 AM   #24
Daaaanz67
It's been hit and more miss for me commenting on the site, you guys that are running the term x or any other Holley stuff. You should look up HCR customs Devin Vanderhoof. He builds his own LS harness. He sells Holley stuff as I believe he's sponsored by them. He is a master at wiring race cars. He uses top of the line Tesil wire. Look him up on the Tube. He puts his harness and the Holley for comparison. His is a little longer for mounting under seat. Seriously, check him out. Not trying to sell anything just like his stuff.
Daaaanz67 is offline   Reply With Quote
Old 11-16-2022, 01:32 PM   #25
biketopia
Devin's stuff is top notch, I know he's a Holley vendor for sure. He's super knowledgeable and his videos are very helpful, even if you're not building a full on race car. He is also very active on the Facebook group he helps moderate.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
