#22 |
Re: monojet ?
Ok so tonight I went out and rechecked some things, sped the idle up a little and readjusted the carb was a little better..
So then I was checking again for vacuum leaks and noticed the dash pot isn't holding, so I plugged that line off. I also had my vacuum advance hooked to full vacuum at idle.. changed that to ported. Seems better but probably should re adjust the carb again since I changed the advance on the timing. My other question is if I do have the metering rod too low would this affect the take off hesitation? |
Tags |
hesitation, monojet |
