![]() Join Date: Jun 2018
New Repair piece for lower right hand side of radiator support
Made by Member “Clatterville trolley”, see: https://67-72chevytrucks.com/vboard/...d.php?t=817982
[B]I never used mine, was $75.00 shipped CONUS (no PO boxes). $50.00! ..... SOLD “I have been making these for folks that I sell parts to for some time and thought I might offer a couple to the folks on here. I hand form these and they come with the weld in nuts and factory OEM bolts. They are made out of 16 gauge steel - I checked the thickness of the steel in the radiator support with a gauge and they appear to be about 17 gauge, so these are a little thicker than stock. I constructed them to be long enough to reach under the upright where the rust normally stops unless it is really baaaadddd! I leave the weld nuts loose so that it allows slight adjustment to line up with the holes in the inner fender front - once you get them where you want them it is easy enough to spot them in. Right now I only have two made up so that is all I am selling for the moment - not trying to turn this into a business. Price $75 shipped to you. First photo shows the replacement piece next to a rusted up one that I removed to replace with new. Last photo shows where the new repair piece goes on a radiator support. Works for 67-72 C10 / K10's”
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White Last edited by CS1972; 01-26-2023 at 10:20 PM. Reason: Sold |
