#3401 |
Re: PO has me PO'd
![]() Found an old piece of sheet metal, seems to fit well with only one relief cut at blue marker, clecoed in place
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-10-2022 at 10:02 AM. |
#3402 |
Re: PO has me PO'd
#3403 |
Re: PO has me PO'd
Rusty metal cut out, now ready to weld new piece in
I prefer to use my small dremel with a cutoff wheel, less intimidating than my angle grinder
#3404 |
Re: PO has me PO'd
![]() Time to move on to the next piece
#3405 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-14-2022 at 10:40 AM. |
#3406 |
Re: PO has me PO'd
![]() Fugly, cut out a template
#3407 |
Re: PO has me PO'd
#3408 |
Re: PO has me PO'd
![]() Not sure if I want to flange this piece for strength
#3409 |
Re: PO has me PO'd
#3410 |
Re: PO has me PO'd
![]() If I may quote HG "if a man doesn't know what you are doing, then he can't say you're doing it wrong
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-20-2022 at 09:34 AM. |
#3411 |
Re: PO has me PO'd
![]() In the aftermarkets infinite knowledge, they decided to leave off the last bit of the B post, down around the rocker So it leaves any attempt to repair flying in the breeze, had to use the old fly cut method
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-27-2022 at 09:19 AM. |
#3412 |
Re: PO has me PO'd
![]() Honestly I don't know how a factory makes this welding stand for 45.00$, do they pay workers. Do they pay workers. 45 cents a/hour or is the metal from old fridgedars Any way good product, now I can get some welding done
#3413 |
Too Dumb To Know Better
Re: PO has me PO'd
Jim,
They sure make it easier don't they. |
#3414 |
Re: PO has me PO'd
#3415 |
Re: PO has me PO'd
[QUOTE=low'n slow;9121612]Jim,
#3416 |
Re: PO has me PO'd
#3417 |
Re: PO has me PO'd
Some reason, stuck on pic7750
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-15-2022 at 11:20 PM. |
#3418 |
Re: PO has me PO'd
No pics till I fix it..................any it guys
#3419 |
Re: PO has me PO'd
#3420 |
Re: PO has me PO'd
#3421 |
Re: PO has me PO'd
![]() Just tacked in, weld in better on inside, then lead to form billet
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-21-2022 at 10:03 AM. |
#3422 |
![]() Join Date: Aug 2007
Re: PO has me PO'd
Hey Jim, that patch looks great, just one more to go. As you know a lot of things in the B pillar area.
7D2N
Just for the fun of it |
#3423 | |
Re: PO has me PO'd
I thought I was through with the B post until I realized the bottom 1/2 rear supports the lower 1/4 panel, would be flying in the breeze, so to speak There is A LOTTTT OF FAB WORK in the B pillar area, at least in the RUST BELT
#3424 |
Re: PO has me PO'd
![]() If you can't weld good, weld alot and grind My preferred method of grinding is my Dremel with a 1 1/2 cut off wheel, far less intimidating then my angle grinder, slower, yes, but far more accurate
#3425 | |
![]() Join Date: Mar 2011
Re: PO has me PO'd
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
