Old 10-31-2022, 06:19 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Picture of factory tail pipe exit on 71ish SWB 402 anyone??
My exhaust guy would like a reference. Don't suppose it matters LWB and SWB. I'm working on a 71 SWB, 402. The pipes exit the rear sides someplace.
A picture and three measurements appreciated a lot.......
.Horizonal distance from the rear fender to tail pipe's exterior:
.Vertical distance from the rear body's bottom to tail pipe's exterior:
.Inward or outward distance from the body's bottom to tail pipe's tip:
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-31-2022, 06:26 PM   #2
72SB
Re: Picture of factory tail pipe exit on 71ish SWB anyone??
V8 or 6cyl?
72SB is offline   Reply With Quote
Old 10-31-2022, 07:46 PM   #3
71CHEVYSHORTBED402
Originally Posted by 72sb View Post
v8 or 6cyl?
402
Tony
Old 10-31-2022, 11:36 PM   #4
mr.mud1
mr.mud1's Avatar
hi Tony,i can get you some measurements tomorrow if you like.here's the new Waldron tailpipes on my 72 truck.they are the same as the originals i took off except 2 1/4 diameter pipe rather than 2 inch because i asked for them that way.everything fit right back on the factory hangers also.
mr.mud1 is offline   Reply With Quote
Old 11-01-2022, 01:30 AM   #5
71CHEVYSHORTBED402
Thanks again Greg, I'd appreciate that.
Tony
Old 11-01-2022, 10:51 AM   #6
mr.mud1
mr.mud1's Avatar
hi Tony.i emailed some pictures to you this morning.if these aren't good enough or you need more,just holler.
Greg
Old 11-01-2022, 10:52 AM   #7
72SB
The V8 pipe exit appears to be same position as 6, which is what I have. Since Greg is sending you his measurements I will hold off. Also I used stock hangers but 2" pipe and had the shop just weld on a chrome turn down tip positioned where "I" wanted it in terms of how far in/out I wanted it so it may not be exactly stock position
Old 11-01-2022, 12:40 PM   #8
71CHEVYSHORTBED402
Thanks for all the help, and I appreciate it again Greg, you've helped me out a lot.
Tony
Old 11-01-2022, 04:51 PM   #9
mr.mud1
mr.mud1's Avatar
not a problem sir,holler anytime.take care.Greg
Old 11-02-2022, 04:20 PM   #10
68 C10 Driver
Maybe a dumb question, but did they do a single exhaust output for the SBC in these trucks? I know that was common in the sedans of that era, but unsure about the trucks.
Thanks!
68 C10 Driver is offline   Reply With Quote
Old 11-02-2022, 05:30 PM   #11
mr.mud1
mr.mud1's Avatar
Thanks!
not a dumb question at all.they certainly did do single exhaust for these trucks with a small block.they all didn't have duals.i worked in a muffler shop when i was a kid so i saw lots of them.recently when i did the exhaust on my truck,i contacted Walker but the answer i got back was that they no longer made the parts for our trucks.i've used Waldron's in Michigan for exhaust parts for several projects now,they still show a single exhaust system for these trucks.all the best.Greg.
Old 11-02-2022, 10:01 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
I've seen it mentioned here somewhere that trucks with small block engines only ever had single exhaust with a y-pipe. I worked on a ton of vehicles from '70 to '72, and only recall a very few dual exhaust vehicles, but no SBC trucks, and I can count on one finger a SBC 400 with dual exhaust, in an Impala. Rare bird, I guess. BBC trucks were always dual exhaust in those years, IIRC.
~Steven
Simi Valley, CA
Old 11-03-2022, 02:06 PM   #13
72SB
LMC sells a single exhaust for a 6 Cyl. Box with muffler that came with mine said Made in Michigan IIRC....don't know if it was Waldrons but system fit was good
Old 11-03-2022, 10:22 PM   #14
71CHEVYSHORTBED402
Exhaust installed, great guy & work. 2.5" fronts and 2.25" rear. Turbo mufflers, they're pretty quiet when not broken
https://www.youtube.com/watch?v=hhM_Mg8MHGA&t=136s
Tony
Old 11-04-2022, 12:26 AM   #15
mr.mud1
mr.mud1's Avatar
looking good.
Old 11-06-2022, 11:10 PM   #16
slikside
slikside's Avatar
Thanks!
Sure did. Mine is a 350 with a Y pipe and single tail pipe that exits just aft of the left rear.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
